FiTech EFI Tuning Tips
you can just copy and paste and then fill in your valves.
ENGINE SIZE:
FITECH SETUP USED:
ENGINE VACUUM:
CAM SETTING (1,2,3, or 4) AND YOUR CAM SPECS:
IAC COUNTS @ idle and cruise
TIMING CONTROL: Y/N?
IDLE RPM:
TARGET IDLE AFR:
ANY ADJUSTED PARAMETERS AND WHY?:
FITECH SETUP USED: go efi 600
ENGINE VACUUM: 15"
CAM SETTING (1,2,3, or 4) AND YOUR CAM SPECS: 3 comp XE262
IAC COUNTS @ idle and cruise idle : 6-7
TIMING CONTROL: Y/N? Y
IDLE RPM: 750
TARGET IDLE AFR: 13.65
A TON. The system gets roughly dialed in and running at steady state conditions quickly. I have transition issues related to the AFR correction. A slight lean tip-in turns into a rich bog when the correction steps in.
I did have lean tip-in issues with the carb so some of it is a motor issue. I'm currently going to try an open 1" spacer on my dual plane intake and start over with tuning.
I also have hot starting issues
