tailgate assist
Old Apr 17, 2018 | 04:38 PM
thatdarncat's Avatar
thatdarncat
Originally Posted by Bandera
Yes, that's right. I had read where some did some did not have them. Mine didn't. I have the tailgate step, so maybe that had something to do with it.
I guess someone knows your truck better than you! LOL
Old Apr 18, 2018 | 06:48 AM
sailorman3's Avatar
sailorman3
Mine is a 2017 Lariat and it DID NOT have the mount on the inside. I bought the "shock" and the ball mount separately CHEAPER than I could have bought the whole kit with both of those parts. I painted my bracket Ingot Silver to match. Installation was easy, and did not have to completely remove the tailgate.
when you say you bought the shock and the ball mount separately, do you mean the balll mount on the hinge or the one attached to the inner fender? I also painted my hinge red to keep it the same color as my truck.
Old Apr 18, 2018 | 04:21 PM
Bandera's Avatar
Bandera
The one on the inside on the lower hinge.
Old Apr 18, 2018 | 04:35 PM
sailorman3's Avatar
sailorman3
[QUOTE=Bandera;17934828]The one on the inside on the lower hinge.[/QUOTE
ya no truck comes with that unless it already has the shock installed. Only the upper ball is on all of the trucks when they are manufactured. The kit comes with the hinge and the shock only. The ball is attached to the hinge in the kit.
Old Apr 20, 2018 | 12:29 AM
AbitaPro's Avatar
AbitaPro
I have used the DeeZee tailgate assist for years, but what I found was eventually the adapter nut that goes inside hole in tailgate, pulled out. After same thing happening on two trucks, finally just installed 2 DeeZee Tailgate Shocks, 1 on each side, no more problems, and using same adapter nut.
Old Apr 20, 2018 | 10:26 AM
function12's Avatar
function12
I noticed on my DeeZee,that I had on my 2012 truck, got very weak after 2 years.
Old Apr 20, 2018 | 10:36 AM
storage_man's Avatar
storage_man
Sooner or later any strut will lose its compression. I think it took about 5-6 years on my 2006 before it started losing compression. It would fall early, but then it still would slow down. It was on the truck for over 10 years.
Old Apr 25, 2018 | 07:45 PM
ecoboost12's Avatar
ecoboost12
Dee Zee Kit
Installation went good the Tailgate Ball mount Plate that you remove the 10 mm Head bolt
that you take out and replace with the Button Head Bolt,Is there a use for this Bolt somewhere
else, I heard no mention of it here. I bought the Dee Zee kit. Thanks Guys and Gals
Old Apr 25, 2018 | 11:18 PM
JKBrad's Avatar
JKBrad
This thread made me remeber that I had a Ford kit in my garage that I ordeed awhile back and never put on. Took about 30 min start to finish, including putting the tools away. It works very well.
Old Apr 27, 2018 | 04:06 PM
CR172's Avatar
CR172
Good to hear as I just received mine in the mail the other day. Going to try to get it installed this weekend. My problem is that I recently had bicep tendon repair done and I'm limited to 5 lbs weight limit for the next 4 weeks. Tore it loose about 3 years ago and finally decided to get it fixed. So now the right arm has had the bicep reattached both at the shoulder and now at the elbow. getting old kinda sux but it beats the alternative.
Old Apr 27, 2018 | 04:30 PM
cbradford's Avatar
cbradford
Installed the Ford kit on my 2017, like that it’s hidden and works fine with Ford tonneau cover. Paint matched to truck before installation.
Old Apr 27, 2018 | 05:19 PM
soundwave's Avatar
soundwave
Can anyone post pictures? I'm considering buy some. I just want to see where they place.
Old Apr 27, 2018 | 05:34 PM
  #28
Michael Jay's Avatar
Michael Jay
There are 2 or 3 videos on Youtube showing the parts and installation.
Old Apr 28, 2018 | 08:30 AM
  #29
BlackNBack's Avatar
BlackNBack
From another forum:
https://www.f150forum.com/f118/how-i...2016-a-341090/
Old Apr 28, 2018 | 05:40 PM
  #30
rbraughn's Avatar
rbraughn
Originally Posted by triniexr
I owned an F250 and now have an F150. I found once you install a tonneau cover this no longer works. I've adjusted the hell out of both trucks and it seems the cover prevents it from opening, it just unlocks now.
My folding MX4 allows it to open and close with no issues
