Need help
Old Feb 6, 2018 | 07:51 PM
2005f2506.0's Avatar
2005f2506.0
Need help
i recently ran into a problem with my truck. i went to work this morning everything running like it should when i was leaving i hit some train tracks little to hard all of a sudden my truck feels like it shifts late its idling lower than normal. ive checked all my fluids everything is where it needs to be and no leaks that i can see around trans and engine, when i went to work this morning i didn't have a problem. any help would be a big help
Old Feb 6, 2018 | 09:11 PM
tfunk88's Avatar
tfunk88
Is it possible you just think you had a problem because you hit the tracks hard and were worried you’d caused damage?
Old Feb 6, 2018 | 10:17 PM
wheelerg's Avatar
wheelerg
I have got air more times than I want to admit from cattleguards on forestry roads. No problems from beating on the truck way harder than I should. But you should look into a loose wiring connection somewhere.
Old Feb 7, 2018 | 07:57 AM
2005f2506.0
thanks for the info
Flip4ford
Kansas Chapter
17
Dec 29, 2010 01:52 PM
96bigblueford
Dec 19, 2007 08:26 PM
kenneBF250V10
Oct 5, 2004 10:55 AM
