Help with Altman Latches
I installed altman latches in my 54 f100 and I am having problems getting them to work properly. The latch moves freely and seems to work perfectly, the door is properly aligned and the **** on the door pillar is lined up with the center of the door latch but when I close the door it jams very tight. I have to press the button on the handle and jerk as hard as I can several times to get the latch to release...
I welded in the altman panels so there isn't much adjustment on that side... I'm thinking that possible the ***** aren't sticking out far enough but I don't know where to start trouble shooting this....
has anyone had any similar issues?
Here is a good photo of what the latch and striker pin should look like when properly setup. On some installations I have had to shim the striker pin to move it out a bit. To do that I used a stainless steel washer that I sanded down to make it the same diameter as the beveled washer on the striker pin. The pin on the green truck has been shimmed...as you can see, the shim is not noticeable.
Jake,
Mine was in the same boat. I used washers to mock up. Then I ordered some Autoloc Stainless Strikers. They were a little longer and gave me enough to clear.
I ordered them through amazon for 9.00 2 months ago. I don't know why the price is jacked up now...
I also had to order them because the striker bolt seized up in the plate, and snapped off. I guess when my door binded shut, the force from me pushing it open bent the striker. I had to cut open the door frame to fix it, what a pain.
Jake,
https://www.amazon.com/dp/B003TVN7IO...coding=UTF8&me=
Also make sure that in the end that you do not use the striker to position the door correctly (up and down). Otherwise cracks will develop over time in the B pillar around the striker.
And if you also have a more powerful engine or heavier engine (diesel) that your frame has been strengthened (boxing, etc) to reduce flex or the same thing can happen.
What di you use to fill over the outer skin seam?
Here ae some from Fastenal:
https://www.fastenal.com/products/details/74115?r=~%7Ccategoryl1:"600000 Fasteners"%7C~ ~%7Ccategoryl2:"600039 Sockets"%7C~ ~%7Ccategoryl3:"602314 Socket Shoulder Bolts"%7C~ ~%7Csattr03:%5E"Stainless Steel"$%7C~
