1966 - 1977 Early Broncos
Front springs
Old Feb 2, 2018 | 05:24 PM
RacerJames's Avatar
RacerJames
Front springs
Back 20 years or so ago, My dad and I were racing a Maverick street stock. what worked at the track we raced was a '74 Bronco front spring in the right front. I spent 10 minutes or so getting frustrated with google, (they kept directing me to Moog variable rate coils, which, I think are cool, but not for my current application). trying to find specs on this spring so I can replicate what we did then in a new race car we're putting together.
Please can someone direct me to spring rates/lengths for stock front springs on a (blue ) '74 Bronco full cab with a 302?
Old Feb 3, 2018 | 08:48 AM
chrlsful's Avatar
chrlsful
1 bronk frnt coil spring
"...'74 Bronco full cab with a 302..."
as U may know there's really no difference '66 - '77 bronco (even w/the 6 v 8 cyl motors, I assume). In fact I'd bet the '73 - '79 F 100 spring would B the same.
It may B difficult to wrench ONE spring outta a sale (don't they go in pairs?) but U could try. "Numbers Dummy" on here may B able 2 get U a part number...
from there U may B able to tell what folks R offering (ask them 2 cross reference to what their part lists out as w/the ford?).
Plenty (a doz?) bronk aftr mrkt vendors (we can help w/names if U wann go this route). Don't 4get the majority R 'progressive rate' (variable) now days - ask 4 the ol school spring, again, I guess).
Last, ford dealer.
Lotta assumptions there, but 's what I can do right now...
(Oh, classicbroncos is THE bronco site & can offer more opinions, only a few facts there but weed ur way thru, there's some w/the real facts).
Old Feb 3, 2018 | 11:27 PM
McLeod's Avatar
McLeod
Little information is available about the original stock springs in an early Bronco.
I did see this from some promotional materials from a '73 Bronco:
Front coils:
6cyl = 1075lbs
302 = 1130lbs
These springs ride much harsher than a modern replacement coil.
Early springs would have been a constant rate spring. Variable rate are more modern and are distinguished by the coil having two or more distinct wrapping patterns.
1966-77 replacement springs are listed the same for 6cyl -vs- V-8.
Moog CC812:
Bar dia. = .64"
I.D. =4"
Free Height = 16.31"
Installed Height = 13"
Load = 808lbs
Spring Rate= 245 psi
VARIABLE RATE
AC DELCO 45H1001
Bar dia. 64"
I.D. = 4"
Free Height = 16.4"
Load = 845lbs
Spring Rate = unlisted
CONSTANT RATE
And as far as 78/79 Bronco springs go, they MIGHT fit but are different from the 66-77 models:
MOOG CC814 and AC DELCO 45H1002 list the same specs:
Bar dia. = .67"
I.D. = 4"
Free Height= 17.5"
Load = 1330lbs
Spring Rate= 271psi
Moog= VARIABLE RATE
AC DELCO= CONSTANT RATE
Maybe there is enough info to help you out.....
Old Feb 4, 2018 | 11:24 PM
McLeod's Avatar
McLeod
Looking through my upper storage in the garage today, I noticed I have an OEM set of clean coils for a 73 or 74 Bronco, along with the red air lift air bags inside them.
Been off the vehicle for well over 20 years.
The spring's bar dia. is the same .64 and the free length is 17 1/2 inches.
In fact, if you want them I will make you a deal on them but most likely shipping costs would be pretty expensive.
Old Feb 5, 2018 | 04:20 PM
RacerJames's Avatar
RacerJames
Thank you for spending the time I didn't Mcleod! I will use the data supplied to make my current car as fast around the track as the old one was - maybe even faster! Welcome to my pit crew.
Old Feb 5, 2018 | 04:47 PM
chrlsful's Avatar
chrlsful
One coil: just makes left hand turns...
yeah, if not interested in 1a his U could make yer own wid all dat info!
omni
May 25, 2006 08:34 PM
Goodold71
Apr 8, 2005 12:59 PM
odb2888
1978 - 1996 Big Bronco
May 19, 2003 10:03 AM
kuss
Feb 24, 2003 06:48 PM
waverunner
May 21, 2002 12:42 PM
