4WD Vacuum Issue
Old Feb 1, 2018 | 07:25 PM
59CRL's Avatar
59CRL
4WD Vacuum Issue
Hello all. I replaced the vacuum solenoid under the hood. Now when you drive down the street the front end feels binding and jumpy. With the 4WD engaged taking turns the front ends binds extremely bad. I pulled the vacuum connector off the solenoid with the SUV running and the red line has constant vacuum. I drove home from work with the connector disconnected and it rides smooth again. It seems like the front hubs are getting vacuum all the time. So the big question is should the solenoid have vacuum on it all the time? Maybe the new solenoid is bad? What do you guys think?
Old Feb 1, 2018 | 09:11 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
The solenoid is connected directly to the vacuum chamber, so YES it should have vacuum to it constantly. When asked to, the solenoid passes that vacuum through its inner workings to the hubs. It might be getting "the signal" all the time, and thus passing the vacuum to the hubs all the time. It might not be the solenoid is what I am saying. Another component could be telling it to pass vacuum to the hubs when you don't want it to. Checking the pins on the plug for voltage is in order.
firegod42
Aug 10, 2017 12:08 PM
rock2610d
Jun 4, 2017 04:39 PM
Chris82458
Dec 16, 2015 01:25 PM
iron1951
Oct 17, 2012 10:05 AM
mackstruck
Feb 26, 2010 11:22 AM
