My 78 F150 Custom 4x4 SWB
#91
Thanks, I've spent most of my time on classic Fords and Jeeps, but have owned 2 AMC Rambler Classic Convertibles (1st project car when I was 12), done basic repairs on various imports, and started a build of a 93 Nissan 240 until my brother lost time, and sold it. We were working on a LS1 and T56 swap for the 240. Within the next 5 years I plan to start cosmetic restoration on my 1996 Bronco Eddie Bauer, my parents' bought it new in Jan 96, and I've been driving it since I was able. It's currently my daily driver, after living through my brothers and I growing up in it, and now my 2 boys, it's in need of some love for the front seats and carpet.
#93
As for the dent... it'll be a couple week's were spending time/energy to get my CJ out of my buddy's shop, where it's been stored since July of last year during the rebuild of all the drivetrain. Once it's done, we're fixing another buddy's Super Duty build, adding in traction bars, and regearing the rear axle. Then I can install the new suspension on the 78 using his 2post Lift. I will post updates between then on the 460.
Feel free to check out the link in my signature to my site, I've got a lot of details on my past builds there if interested.
#94
Put the Ol Truck to work over the weekend, 2 loads of mulch then moving some stone around on our property...
Started noticing some fairly major driveline vibrations under load/acceleration, found one of the u-joint caps coming apart at the rear pinion yoke. So it’ll be parked until i get 3 new u-joints & double cardan joint & rebuild the rear driveshaft. Just glad I caught it before it spit the shaft.
#95
#96
#97
#98
#100
A few... haha, found reason of U-joint failure, After my surgery last summer, I forgot to retorque the ubolts after a few miles on them.
Block with quick coat of engine enamel, still need to scrub cylinders with hoat soapy water & abrush to get last bit of machining residue out before I start assembly. Before that I need to focus on getting interior back in the Galaxie & cleaning my shop space.
#101
Looking for quick recommendations/solutions...
pulled suspension apart to install lift & had the 4 total lower coil retainer/cup bolts snap off. My buddy & I with combined 50+yrs experience threw every trick we know at it. Welded nuts to bolt remnants, heating bolt in process til cherry red, while also heating the radius arms/csps. Just ended up snapping the last nub of the bolt off nearly flush with the arms...
#102
I'm not experienced with this, but...
Dry ice? I work with cultures and they're kept with dry ice when they're delivered, so it's always the first thing I think of.
Heat cycle it? Like get it super hot and then super cold and see if it loosens anything?
If it's more than just a rusty grip on things, I'd have no clue other than a tap and die/drill, if that's even an option.
#103
#104
Need drill press or mill. Id say at this point your only option is to drill and retap or buy some good used caps. Maybe hit this guy up see if he has more
https://www.ebay.com/itm/73-79-Ford-...EAAOSwi3tbFLpf
#105
