6.2L V8 Discuss the 6.2L V8
Spiral Dipstick?
Old Jan 28, 2018 | 04:43 PM
Bill The Cat's Avatar
Bill The Cat
Spiral Dipstick?
I performed a search and didn't find any info on this...
I took delivery of my truck (2017 F250XL 6.2L) about three weeks ago and after driving it about 100 miles realized that I hadn't checked the oil level. Just went outside and pulled the dipstick and it was like it didn't want to come out. It wanted to spin as I pulled on it, so I let it do so and finally got it out.
The top 12" or so are straight, and then it's like that section is riveted onto a bottom section that is twisted into a spiral for the entire length that extends down into the oil in the pan. It doesn't look like it was wadded up by the factory or anything, as the spiral has a very even twist down the length of it. It wasn't easy to get it to go all the way back down the tube when I replaced it. The newest Ford I have to compare it with is a 2011 Fusion 6cyl and it has a "normal" dipstick.
Is this what Ford is using now? Spiral?? If so, why?
Thank you in advance for any replies. For what it's worth the oil level was fine.
Old Jan 28, 2018 | 04:55 PM
leadmic's Avatar
leadmic
It's normal, Ford fills the truck with proper amount of oil than twists the dip stick to shorten it until it reads full. Fords not the only manufacturer to do this and it's been done for year's on certain style dipstick. To make it easier to put in and take out you have find the sweet spot just keep turning it until you find it.
Mark
Old Jan 28, 2018 | 05:28 PM
cattaco's Avatar
cattaco
Dipsticks suck, it is known.
Old Jan 28, 2018 | 05:49 PM
Bill The Cat
Thanks for the replies!
Twisting the dipstick to get it to the right length seems crazy to me. How hard can it be to engineer one the right length to begin with and be done with it? Seems like a task you'd give the rookie engineer on the design team LOL
I figured the spiral would be to add some friction to help keep the stick in place, or to give the oil mist more surface area to latch onto and drip back into the pan.
Old Jan 28, 2018 | 06:05 PM
tibadoe's Avatar
tibadoe
The first time I checked the oil it was a bit awkward. But once you check it a couple times, you will get the knack of it. I don't even think twice about it now.
Old Jan 28, 2018 | 06:39 PM
RainDesert's Avatar
RainDesert
Mark
Seriously? I have never heard that explanation before.
Old Jan 28, 2018 | 07:35 PM
leadmic's Avatar
leadmic
Just cause you never heard of something doesn't mean it's not true. If you think about it adjustability is not a bad thing, this engine is going into a lot of different vehicles. In each vehicle the engine sets at a different angle. The back of an F250 sets lower than the back of a f350 ect...
A lot of large diesel truck have the same type of dipstick because they go into different types of vehicles.
Mark
Old Jan 28, 2018 | 07:40 PM
RainDesert's Avatar
RainDesert
Mark
I don't think it's not true. Just saying I've never heard of that or any other reasoning.
Old Jan 28, 2018 | 07:51 PM
FishOnOne's Avatar
FishOnOne
Never heard of that one either. With precision block casting and die stamped oil pans there's really no variables that would require a calibrated dip stick.
Old Jan 28, 2018 | 07:55 PM
leadmic's Avatar
leadmic
If you think about it if an engine is going into one car with one spring option than the dipstick length can be static, but if it's going to be at different angles it helps to have it adjustable.
Mark
Old Jan 28, 2018 | 08:05 PM
h20camper's Avatar
h20camper
The dipstick does suck. Sure wish there was an after market option.
Old Jan 28, 2018 | 08:13 PM
RainDesert's Avatar
RainDesert
Mine must need a half of twist taken out because everytime I change the oil and fill 'er back up with 7 qts, it shows about 1/2 full. I don't remember my old '97 F150 4.6 stick having twisted dip sticks though, and I know that motor went into cars, trucks and vans. Come to think of it I don't think the 7.3 PS did either. Maybe the twist method is the now preferred over several different length sticks for the same motor.
Old Jan 28, 2018 | 08:39 PM
leadmic's Avatar
leadmic
If you know you put 7qts in their is nothing to stop you from readjusting the dipstick, in fact you should as long as it's on level ground at normal ride hight.
Old Jan 28, 2018 | 10:06 PM
dkf's Avatar
dkf
Not a fan of the dispticks for the engine oil or the trans. But at least they put them on and didn't eliminate them. They probably will axe both in the future. Also not fond of the fill on the valve cover, stupid angle that you should have the special funnel for. Too much for Ford to put an extension on like they did on the modulars for decades.
Old Jan 29, 2018 | 01:33 AM
don123's Avatar
don123
Never had a problem with the dipstick on my truck but I don’t like how ford rivets the oil dipstick together. It should be one solid piece.
