Need serious help please...
Old Sep 14, 2003 | 09:14 PM
Patbo's Avatar
Patbo
I have a 91 eddie bauer when i put it in gear it jumps foward and dies in runs good in N and P just when you put a load on it it wont move or stay running,and with it jacked and running you can go through all the gears just fine but you hit the brakes it shuts off,any ideas,thanks
Old Sep 15, 2003 | 12:48 AM
RRMike's Avatar
RRMike
Sounds like the torque converter is locked up. It should slip when you put it in gear but it's not.
Old Sep 15, 2003 | 12:54 AM
Patbo's Avatar
Patbo
Yeah it dont do nothing but die when i put it in gear,so i need to replace the converter then?thanks for the info rrmike
Old Sep 15, 2003 | 06:56 AM
BigBlueFord's Avatar
BigBlueFord
not necesaraly replaceing the converter would solve it, it might be a computer problem or a sensor problem, since the lock-up of the converter is computer controlled. Take it to a trans shop and have it diagnosed!
Old Sep 15, 2003 | 08:05 AM
Native Gearhead's Avatar
Native Gearhead
You can also take it to Autozone and ask them to scan it for you (its free). Then see if you can make sense of the codes. If not, post the codes here.
