flywheel
Old Sep 14, 2003 | 09:07 PM
hillbillyk's Avatar
hillbillyk
flywheel
I have a flywheel for my 400, not sure if it is off a 351m or 400, It has 2 different sets of holes on it, one set is threaded and are in groups close together, the other holes are not threaded and are evenly spaced along the edge. I would like to run the 12" clutch, but don't know if I can use it, which holes do I use, do I need to thread the even spaced holes for the clutch? I know very little about clutches.
Old Sep 15, 2003 | 12:42 AM
bubbaf250's Avatar
bubbaf250
flywheel
Sounds like a 351M flywheel. Measure the distance (center to center) between two of the threaded holes on opposite sides of the flywheel. If the holes are spaced 12 5/8" apart, its a 351M flywheel (11" clutch).
Old Sep 15, 2003 | 11:51 AM
Brian S's Avatar
Brian S
flywheel
http://www.pressenter.com/~drauchw/F...hFlywheel.html
