Code 41 - SOLVED!
Old Apr 15, 2022 | 05:15 PM
  #46
JJLOPEZ's Avatar
JJLOPEZ
Try
Originally Posted by _Clayton_
I have the code 41 as well. Mine does the same annoying cold idle high rev, A quick blip of the throttle will bring it down if I dont wanna wait for it to come down on its own. It will stall sometimes when going from reverse to drive or from either to neutral. It will also hold a bit of a higher idle on warm restarts and will eventually taper down. It has plenty of power and seems to run fine otherwise, But it drinks gas and I mean bad. I'm getting ready to install some shorty headers so I'll attempt to deal with it then. It needs valve cover gaskets and the lower intake resealed, it's seeping oil out the front. I'm doing a double roller timing chain and possibly a very mild cam while its apart. If it aggravates me to much I'll carb swap it right now.
TrY CHANGING YOUR TPS ,,
MINE DIED WHEN I WENT IN REVERSE ,,,AND HIGH REV AND LOW MISSFIRING
1989FordF250
28
May 10, 2022 07:42 PM
latechbanjo
26
Nov 26, 2017 10:14 PM
afunk
Jul 20, 2006 06:06 PM
stangdano
Aug 9, 2005 10:15 PM
dan_da_mick
May 3, 2002 02:08 AM
