Hello, I drive a 2012 F150 3.5 Turbo. about 108 k miles. I had to have the ABS and PCM reprogrammed due to loss of communication with ECM. After the reprogram my cruise control will no longer come on. The light doesnt come on in the instrument cluster or anything. Dealer says they cant get it to take the new program when they hooked it up to reprogram this morning. All my other electronics work. IS there anything else I need to do?
Shouldn't be anything you need to do. Sounds like the dealer didn't program right or you have a bad module. My guess is on the second one though if it lost communication and wasn't replaced.
Thanks jdunk54nl, They said it wouldnt take the reprogram at all. They want me to bring back in and let an electrical tech look at it. Since only the shop foreman was the only person available to look at it the first time. They think the electrical guy can maybe do a manual override and maybe it will take the program. Just strange that the cruise is the only thing affected and no other electrical systems. The estimate to replace module is like $860 which is insane
