2 solenoids
Old Sep 14, 2003 | 08:11 PM
elstx's Avatar
elstx
2 solenoids
My truck had 2 solenoids - why???
Old Sep 14, 2003 | 08:15 PM
elstx's Avatar
elstx
2 solenoids
Actually, I know it's because it use to have 2 batteries. But now that there's only one battery, why is there 2 solenoids?
Old Sep 14, 2003 | 09:26 PM
Opiewan's Avatar
Opiewan
2 solenoids
my camper special was that way too. i just unhooked the extra one and only run one battery now. and you dont have to post twice, you can go back and edit your post withen an hour i think,
Old Sep 14, 2003 | 09:34 PM
elstx's Avatar
elstx
2 solenoids
Mine came with one battery, but both solenoids were hooked up. Had 2 cables from my + terminal going to them. One has the starter coming off. The other one has several wires that head towards the firewall, but hard to trace from there due to numerous changes over the years.
Took hot wire from 2nd solenoid, and didn't lose anything. However, truck won't start unless I touch 2nd solenoid wire to battery post then start it. Any ideas?
Old Sep 14, 2003 | 10:06 PM
Mike W's Avatar
Mike W
2 solenoids
The ignition switch puts +12 to the S term on the solinoid to operate it.
Old Sep 14, 2003 | 10:11 PM
elstx's Avatar
elstx
2 solenoids
Okay. I have the + wire from the battery to one side, then the starter cable off the other side. So if the ignition goes to the S term, what's on the other post(s)?
Old Sep 14, 2003 | 10:38 PM
MuchToMyDelight's Avatar
MuchToMyDelight
2 solenoids
maybe the neutral saftey switch? i dont have anything on mine, come to think of it...
