99 Exp. EB does not crank over
Old Sep 14, 2003 | 07:52 PM
loonybin88's Avatar
loonybin88
Unhappy 99 Exp. EB does not crank over
the starter does not crank when key is turned. the battery, starter and alternator are good, had them tested. this was an intermitant prob it is not any longer. all the lights/bells and whistles come on then turn off when key is turned to start, like they should, but no starter reply.
Does the anti-theft "Security Key" system stop the truck from actaully cranking?
My next thought is the TR sensor. any feed back?
Any other idea?
I have pulled the codes from the PCM, but there were none.
thanks in advance
jason
Old Sep 14, 2003 | 08:07 PM
buzzard's Avatar
buzzard
Starter relay would be my guess. Engine should still crank, just won't run without the PATS key.
Old Sep 14, 2003 | 08:23 PM
PaulC's Avatar
PaulC
relay or starter solenoid mounted on the firewall next to the battery (under that dark plastic shield that resembles a waterfall).
Old Sep 14, 2003 | 08:49 PM
loonybin88's Avatar
loonybin88
Smile 99 Exp. EB does not crank over
Thanks to the both of you. I will ckeck it out. And let you know.
jason
Old Sep 14, 2003 | 09:08 PM
loonybin88's Avatar
loonybin88
Thumbs up 99 Exp. EB does not crank over
Buzzard, PaulC;
Arcing the solenoid got it to start right up. I was unaware that Ford still used them. I had a 76 F350 years ago and was forever replacing it. I guess I should have just stopped and thought a bit.
However the radio now does not work. and the Climate control does not show the current outside temp when turned off. Related to the solenoid issue? related to each other? possibly both?
thanks again.
jason
Old Sep 15, 2003 | 09:48 AM
buzzard's Avatar
buzzard
Sounds like a fuse to me.
