Please need HELP!!!!!!
Old Jan 25, 2018 | 02:11 PM
AllaboutMPG's Avatar
AllaboutMPG
When you say complete engine harness did you take the PCM connection apart? If not check and make sure it's all the way together
Old Jan 26, 2018 | 01:08 PM
jr2000sd's Avatar
jr2000sd
Good news guys and pretty stupid on my part after I put the harness together I started it up and it started to run bad I unplugged the driver side valve cover harness and it did not make a difference so I pulled the valve cover and the harness was unplugged just enough to make it bad connection so I did the $0.25 trick and it's been running good ever since now I feel like an idiot but thanks for all your guy's help
Old Jan 26, 2018 | 01:22 PM
brian42's Avatar
brian42
Veteran: Navy
No worries. Glad you fixed it. I've had my share of those moments too. Plus now anyone else with this issue will be able to follow what you did.
Old Jan 27, 2018 | 01:26 AM
SpringerPop's Avatar
SpringerPop
Thanks for closing the info-loop on this.
Not everybody does, and it kinda' leaves us hanging.
Don't feel like an idiot, as the simple stuff gets to all of us, sooner or later!
Again, thanks!
Pop
rjd04powerstroke
Aug 5, 2008 02:20 PM
DixieDirt
Oct 18, 2007 09:44 AM
Ilikebigtrucks
Nov 30, 2006 11:52 PM
REALFATBOYHD
Aug 4, 2006 04:11 PM
