Just a Ford 302 Speed Density vrs. MAF Question
Does anyone know if the Ford 302 5.0 that was used in the LTD Crown Victoria was Speed Density or MAF?
Also the same question for the 302 5.0 that was used in the 1995 Explorer? (Edited)
I have heard some say it was SD and some say it was the MAF?
All input is welcome.
And I didn't know that the LTD, Crown Vic's came in the 302 line. I only knew them as having 351's, and puny cams.
Hopefully others will chime in and perhaps correct me.
on
The Expedition didn't exist until '97 and was never equipped with a Windsor pushrod motor. Did you mean Explorer?
I see the error of my ways. I did not mean Expedition but I did mean "Explorer". I will edit my original post. Sorry for the confusion.
95 didn't have the 5.0 if I recall. If it did, then it's got the better GT40 heads, the 97 will likely have the GT40P heads. The switch was made in mid 97. Check the casting letter in the front corner of the passenger side head (and rear corner of the driver side head) The non P heads will have "GT" cast there. The "P" heads have a "P" there. P heads have smaller exhaust valves and that funky spark plug angle that complicates header choices.
But be advised Cobra heads were milled a couple extra passes to get the chambers to 60 cc's so you shouldn't mill them more without first checking the chamber volumes first.
on
Good point, but of course I would think someone building an engine would measure things first regardless what head they are starting with. In this case the casting number is a bit of a giveaway.. F3ZE or F4ZE but then again.. if buying used heads you never know what the previous owners did to them.
While that's what the Ford said they did in reality you can find GT40 heads that came off of a Cobra Mustang with 65 cc combustion chambers. I have such a set.
Ok, good for you. You just proved what I've also seen over the years about Ford's manufacturing practices. You never know what you'll find until you take a Ford engine apart.
