Fuel gauge sending unit
I have had an issue for several months now with the F350. I can fill it up and it reads full. When I drive it the needle drops down and when it hits the halfway mark it goes back to full. I haven't pushed it past that point too much but it's there now. However, I can put about 18 or so gallons in it at this point when it goes back to full on the gauge. I have been keeping up with the mileage on the odometer to know where I am and has been fine but want to get it fixed.
About 10 years ago I did the hutch and harpoon mod on it. I remember putting in a new tank supply return sending unit assembly because I think it was doing something like this at the time back then...just can't remember. I recently did the hutch and harpoon mod to the Excursion because the tank filters were dirty and starving the pump for fuel. I put in a new tank supply return sending unit assembly after cleaning the tank. I still have the sending unit from the Excursion and it wasn't having fuel gauge reading problems.
Has anyone had issues like this? I am thinking it is probably the sending unit but want to make sure before I pull the tank assembly. Also, I know the Excursion has a different size and/or shape tank so am wondering if I can somehow utilize the sending unit from it but don't know if the fuel level arm assembly will interchange.
The float is a black plastic unit. I looked at the unit I pulled out of the Excursion and the plate the sending unit mounts to is steel, and rusted. Why the rest of the unit is stainless is beyond me! I am guessing after looking there are wiring issues...maybe bad ground because of the rust.
elroy6468
05-13-2015 04:23 PM
Shorty 66
04-21-2009 07:44 AM
Manwith3fords
09-30-2003 02:12 AM
