Front Air Dam?
Old Jan 22, 2018 | 10:13 AM
stewy604's Avatar
stewy604
Maybe I'm one of the few that actually doesn't mind the factory 4WD valence?
Old Jan 22, 2018 | 10:18 AM
UpInSm0kE's Avatar
UpInSm0kE
Originally Posted by MNSuper
What's the part number on the 2WD version?
Here is the 2WD Part Number HC3Z-17626-AD. I put this on my truck as well, looks way better.
Old Jan 22, 2018 | 11:13 AM
troverman's Avatar
troverman
Originally Posted by doucetrr
Instead of cutting it, I removed the piece of plastic attached to the bottom of the front bumper when installing my snow plow. Is there any significant benefit to air flow, or any other reason why I should not leave it off? Thanks..
The air dam gives you improved fuel efficiency. That's why it is there, no other real purpose. The 2017 air dam is a more significant piece than it was on all previous Super Duty trucks, and unfortunately the cuts in it for a snowplow are substantial...at least with Fisher. My cuts are almost 5" wide for the push frame to come through and allow room for the plow frame to mate. Somewhat ugly, but I'm leaving it on for any fuel economy it adds.
Old Jan 22, 2018 | 11:32 AM
doucetrr's Avatar
doucetrr
Can my fuel mileage get much worst?
Old Jan 22, 2018 | 09:48 PM
mciokiewicz's Avatar
mciokiewicz
Originally Posted by bow_hunter78
What did you use to cut it? Jigsaw, Bansaw, Hot Knife? Curious. I am thinking of cutting mine down or even fabing a metal one and water jetting it.
I cut mine down using a razor knife with the valance still attached to the truck, this way it was firmly secured and didn't have to deal with removal/reinstallation. I measured up 4" from the bottom all the way across, marked it with painters tape, and then made my initial score. I took the tape off and then made the finishing cuts. In my opinion it looks better shorter, and I am not concerned with whatever fuel mileage loss that's incurred. I chose this method instead of purchasing a 2wd valance to save the money, and after finding a very detailed post from another forum (I'm a new member here and am not sure if I'm supposed to post references to other forums). I then removed the car catchers that hang down from the frame.
It looks like the tape is crooked from the passenger side, but it ripped while unrolling and I corrected it when I restarted.
After the cut, car catchers still on.
I just did this a couple days ago and have been sick as a dog since that night, I don't have a pic after taking the car catchers off, and it was night time when I finished, but I can put one up if anybody would like.
Old Jan 23, 2018 | 03:55 AM
doucetrr's Avatar
doucetrr
What are car catchers?
Old Jan 23, 2018 | 07:31 AM
troverman's Avatar
troverman
Also known as "Prius Catchers," they are the pieces of metal that hang down from the frame as seen in mciokiewicz's second picture with the cut air dam. Because the frame of the Super Duty sits high up, it would not make direct contact with the bumper of another vehicle but likely overrun it instead.
These were first seen on the Excursion years ago.
Old Jan 23, 2018 | 08:25 AM
Turbo Dog's Avatar
Turbo Dog
Just my guess but I doubt it makes any fuel mileage difference with a plow on the truck. I also don't think it has to do with fuel economy, I think it is used to create a slight negative pressure under the truck at high speeds for stability. I'll be adding a big one to my old '67 when I take it out on the salt flats.
Old Jan 23, 2018 | 09:01 AM
troverman's Avatar
troverman
Nope, it won't make any difference with the plow *on* the truck, but it helps when it is off by smoothing the airflow. Downforce might be important on a high-speed vehicle, but in the case of these Super Duty trucks it is strictly for fuel economy.
Old Jan 23, 2018 | 11:06 AM
doucetrr's Avatar
doucetrr
I believe mine came off during the plow install. Fisher called them compliance somethings.
Old Jan 23, 2018 | 12:29 PM
Barbero's Avatar
Barbero
This is the first post that makes sense of why the four-wheel-drive air dam so long. They're there simply to cosmetically cover the car catchers. Am I correct that the car catchers are not on the two wheel drive models?
Old Jan 23, 2018 | 12:44 PM
ERock62's Avatar
ERock62
Did the 2wd valance on a few month ago. Notice zero difference with my mpg's.
Old Jan 23, 2018 | 01:34 PM
  #28
Krabill's Avatar
Krabill
Does anyone have a pic with it totally removed? Any of you all driving around like that? after unbolting the prius catchers of course
Old Jan 23, 2018 | 02:04 PM
  #29
1956Fatfenders's Avatar
1956Fatfenders
Air dams for years have been used to create a low pressure zone behind them. This helps pull air through the radiator and provide better cooling.
Not sure how much difference it makes pushing a brick wall through the air, gas mileage wise, but maybe a little. Maybe its only purpose it to hide the underside of the truck when viewed from the front? I replaced mine with the 2WD version. There's so much less wind resistance, now I'm getting 25+ mpg...
Old Jan 23, 2018 | 02:17 PM
  #30
Buliwyf's Avatar
Buliwyf
They definitely have an aero effect for mileage. Semi-trucks have been running them for years. Notice that the non-aero semi's, don't. If they didn't work, they wouldn't have 87 bolts holding them on.
-The cut on the mirrors, they aren't square anymore.
-The more raked windshield.
-The chunky tailgate. Notice that Dodge and GM also have that now. Why isn't the tailgate flat? That duck tail spoils the airflow, to reduce drag.
-Notice how the truck looks square and classic on the front clip when viewed from the side. But the hood and fenders are beveled.
-Skinny tires.
-Blocking the front axle helps economy. A motorcycle has a worse coefficient of drag than a school buss. That axle has more drag than your grill.
-Even the roof clearance lights are egg shaped.
The radio guy missed the memo though. No idea why these trucks don't have the radio antenna in the windshield.
It's just convenience that they can hide the car catchers there. Weird though, did the car catchers help a frontal safety rating? Or is this a preemptive thing? I don't recall a law that says they need to be there.
