03 Explorer 4.6l Romeo water in valve cover
Hi all,
I have a 4.6l Explorer that has done approx 150k miles and am getting water mixing with the oil only in the rocker covers on both heads. Have read in some posts that this could be condensation but its my daily drive and doesn't sit around that long. I loose water from the radiator holding tank but am not getting water in the sump. Have done gas leak test in radiator to find nothing, pressure test on radiator to find it holds at around 17 psi, I am at a loss to know what could be causing the mayo. Could it be a cracked water jacket in both heads or could it be an intake manifold leak ??? I would pull my hair out if I had any. Please help a Bloke who enjoys driving his car.
Cheers Rick
Cheers Rick
Thanks for the reply freakify,
yes the truck gets to temp and will run all day even at 65 - 70 mph. I'm not sure but the PCV valve is that the breather that comes from the top of the valve cover and recuirculates air back into the intake ? If yes then I would have to take valve cover off to check to see if its heated because all I have is a hard plastic pipe from both covers back to intake. I'm no mechanic so may sound like a silly question
mOROTBREATH
16
03-03-2017 08:16 PM
andrew's64
01-18-2016 02:54 PM
cjben
04-02-2010 10:00 PM
manlikesford
01-04-2003 01:54 PM
