I have recently bought a 93 Aerostar 3.0 and the reverse lights don't work. I have checked the fuse and bulbs, and no problems with them. Is there a relay for them and if so where is it located?
Or any other suggestions would be helpful, thank you.
Move the shifter through the gears very slowly and see if the back-up lights come on at any time. If they do, but not when the trans is in reverse, then the shift linkage needs to be adjusted.
If you can't find a helper, try this at night & watch for the glow in the mirror. Turn the key on but leave the engine off so you don't have to hold the brakes (and have the brake lights on).
