1978 - 1996 Big Bronco
dropping in a 5.8 (block casting #'s?)
Old Sep 14, 2003 | 03:19 PM
monkei's Avatar
monkei
can anyone tell me if a 351w d9ae block will fit my 92 bronco with a 302?
thanks.
Old Sep 14, 2003 | 07:05 PM
ecarter50's Avatar
ecarter50
351w has the same bellhousing bolt pattern and motor mounts as 302. 302 uses different upper/lower intake, dist, oil pan/pickup tube, etc than 351.
Old Sep 15, 2003 | 04:53 PM
monkei's Avatar
monkei
sounds like a yes. do you know if the fact that the block is a 79 matters? where would i find more info on the 'd9ae' code?
thanks
Old Sep 15, 2003 | 05:12 PM
ecarter50's Avatar
ecarter50
Year of the block doesn't matter, 351w EFI setup will bolt on any year block. How to decode Ford part numbers.
Old Sep 16, 2003 | 01:10 AM
monkei's Avatar
monkei
so if i wanted to make it smog legal with a maf conversion the year of the block has no bearing on egr and other emissions crap?
im trying to convert my 302 bankfire/speeddesity to a 351 MAF sequential efi. id like to make it CA smog legal.
