2021+ Bronco Discussion for the upcoming 2021 Ford Bronco!
stumped
Old 10-23-2018, 09:07 PM
Gregory Goss's Avatar
Gregory Goss
Gregory Goss is offline
stumped
I have an 03 7.3 PSD bad oil smoke from exhaust, and pretty good blow by from oil fill. Did buzz test all good, did cct test showed #3 bad, pulled glow plugs on right bank did compression all 350-360 psi, pulled #3 injector sent out had tested came back good. Injectors are Stubbs stage 1 single fire with about 35,000 miles on them. Also has adrenaline pump, Garrett turbo, gearhead chip. Any Ideas what could be wrong ?
Old 10-24-2018, 10:29 AM
fordguy2100's Avatar
fordguy2100
fordguy2100 is offline
Probably have better luck gettin help if you post in the superduty section. This is the 2020 bronco section. Not much here but speculation over whose salesman "knows" more info about the unknown bronco. Lol
I'll give ya a hint... nobody's salesman knows squat.
pcarr4
16
12-01-2015 02:18 PM
VR6Nutt
24
08-11-2014 12:51 PM
kingford72
21
12-22-2010 10:45 AM
mrblonde108
1999 to 2016 Super Duty
11-22-2010 09:08 PM
serviceguy
06-10-2010 11:15 AM
Quick Reply: stumped
