Rear Drum Brake Question
Old Jan 14, 2018 | 08:12 PM
jmstuede's Avatar
jmstuede
Replacing rear drum brakes for 1972 F250 4WD. Old pads are 2.5" in width but in searching for replacements, there are also 3" pads. Do I have the option to use either size? Also, are there US made suppliers for these and the associated hardware? Thanks for any help.
Old Jan 14, 2018 | 09:35 PM
fe390pc's Avatar
fe390pc
You have to use 2.5" shoes. As far as hardware it is a crap shoot. I think you can get some parts from Dennis Carpenter. The other option could be to find a Wagner Kit as I believe they are made in the US.
Old Jan 14, 2018 | 09:37 PM
fe390pc's Avatar
fe390pc
As for the Shoes, you are on your own there. I know there used to be small shops around that actually rebuilt pads, shoes and clutch discs but not sure if any are still around.
Old Jan 14, 2018 | 11:14 PM
willowbilly3's Avatar
willowbilly3
I always go to Rock Auto first on that stuff. They usually have several choices and sometimes good close out prices
Old Jan 15, 2018 | 04:33 AM
GaryKip's Avatar
GaryKip
2X on willowbilly3's comments. I thought Raybestos was made in the USA.
Old Jan 15, 2018 | 07:44 AM
ultraranger's Avatar
ultraranger
Wider brake shoes can't be added unless you change out the drums and the backing plates too.
The wider backing plates have a greater inboard offset, towards the center of the rear end housing, to accommodate the wider shoe width.
Old Jan 15, 2018 | 08:06 AM
willowbilly3
I went with some of their cheapo Centrix stuff on my 59. Got a wheel cylinder that was boxed wrong and the hoses look pretty crappy next to the originals. It's about the only complaints I have. Stay with Wagner, Raybestos, Dorman. The better names.
Old Jan 15, 2018 | 11:50 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by jmstuede
Replacing rear drum brakes for 1972 F250 4WD. Old pads are 2.5" in width but in searching for replacements, there are also 3" pads (no such thing on F250's of this vintage).
1967/75 F250 4WD: Front brakes are 12 1/8" x 2" .. rear brakes are 12" x 2 1/2."
12" x 3" front/rear brake shoes: 1967/72 F350. Or rears only 1968/79 F350 with front disc brakes (optional: 1968/72 / standard equipment 1973/79).
All 1953/78 F350's are 2WD .. 1979 was the first year that F350's were available with 4WD
ckf100
Mar 27, 2015 04:55 PM
little dutch
Dec 4, 2009 03:29 PM
alfama351
Mar 24, 2007 09:27 AM
AllFords1022
Nov 15, 2003 06:01 PM
