If you are hitting the bump stops on a super duty, you are out of control or overloaded.
Except for off roading. I’ve had to cross some serious terrain where full articulation is needed and hitting bump stops can hinder the trucks ability to fully flex.
Just be prepared to put bigger wheels and tires on after the level. Once started its hard to stop...
LOL, so true indeed. My kit came last week and trying to wait for spring to put it on..........not easy. So in the mean time I'm looking at tire/wheel combos
Snow plow prep isn't even close to level but it is the tallest riding front end you can get.
It is simply a taller/stiffer coil spring, really not even taller, simply doesn't squat as much as the other coils.
Thanks for the clarity.
I have an older, 2003 F250 that I bought brand new. I remember back then, it was the snow plow package that would make the truck level, or at least that was what I was told.
