HEI Ignition Conversion (Pre-project)
Old Jan 15, 2018 | 08:00 AM
palmrose2's Avatar
palmrose2
I used a 1" phenolic spacer under a Holley 600. OEM air cleaner clears.
Old Jan 15, 2018 | 02:54 PM
gittinwidit's Avatar
gittinwidit
HEI distributors eat caps. You'll find yourself pulling the cap and sanding down the contacts every few months. And after about the 4'th sanding, they are gone. Another issue is the spring under the center contact goes bad before the actual contact piece. But you buy a set, not just a spring. I converted a 302 and bought the 10 pack of distributor caps.
At least that's my experience...
Old Jan 15, 2018 | 06:52 PM
palmrose2's Avatar
palmrose2
ALWAYS buy caps with copper. Ford, Chevy, Chrysler, IH, Hudson, Nash, Packard, whatever. You see the inside of a distributor cap and it's laced with aluminum? You put it back on the shelf. Why you would have to buy caps by the gross is beyond me.
To all you guys dissing GM HEI ignition. In the 70s, when it first came on the market, the fact that you could change the spark plugs and cap every 50,000 miles and keep on trucking was a big deal. I was there. It still ain't a bad deal.
Old Jan 16, 2018 | 02:30 PM
LittleBlue79's Avatar
LittleBlue79
I'm on the same cap one year later no sanding of anything. And I daily drive the truck. What brand caps do you get?
Old Jan 20, 2018 | 06:44 PM
lafermedavid's Avatar
lafermedavid
HEI
Been grinding and welding on thermostat,for 460 swap,what hold down clamp did you use ?
Old Jan 20, 2018 | 09:16 PM
palmrose2's Avatar
palmrose2
351M Used the original clamp and screw. 460?
Old Jan 20, 2018 | 10:37 PM
LittleBlue79
I used the oem hold down, without issues on my 460.
Old Jan 21, 2018 | 08:13 AM
lafermedavid
hold down clamp for hei
it handled the width of the hei?or did you have to open it up?thanks
Old Jan 21, 2018 | 08:29 AM
84espy's Avatar
84espy
I also used the original hold down on my 460 without any modifications. The extras I had to do was the gooseneck, upper radiator hose and air filter.
Old Jan 21, 2018 | 09:03 AM
LittleBlue79
I didn’t have to make any modifications to the hold down. I didn’t make any modifications to the water neck. I didn’t make any modifications to the upper hose.I do have an aftermarket intake and air cleaner so I don’t know about clearance issues with that.
Old Jan 22, 2018 | 10:07 PM
Idaho Highboy's Avatar
Idaho Highboy
Veteran: Navy
Hey, thanks all for your experience and it sounds like no one has an opinion on whether the 50K unit is adequate for the old FE. Seems like I may (or may not) run into issues fitting a larger cap in the same space as the one in there now. I think I'll hold off replacing the dizzy for now, as many of you point out there is no real advantage. My original motivation was easier cold starts and potentially improve my mileage.
Old Jan 22, 2018 | 10:40 PM
LARIAT 85's Avatar
LARIAT 85
"Easier cold starts?" What is your starting procedure and how is your truck starting now?
If you have a working choke and your truck is hard to start when cold, then something isn't right.
I am running a stock DuraSpark II ignition, and my truck started right up last week at temperatures in the single digits with only a single pump of the gas. I drove away less than a minute later without any sort of stalling or hesitations whatsoever. In fact, other than giving it that shot of fuel in the morning to set the choke and kicking the fast idle cam down to the second notch a few seconds later, I can't tell a difference between my carbureted F150 and my wife's fuel-injected Mustang.
Old Jan 22, 2018 | 10:58 PM
  #28
willowbilly3's Avatar
willowbilly3
I had an otherwise bone stock 72 300-6 I converted to Duraspark II and it would always start at minus 30 without being plugged in, even down to minus 36 once. I lived in a cabin in Alaska and didn't have the luxury of electricity.
Old Jan 23, 2018 | 09:45 AM
  #29
LARIAT 85's Avatar
LARIAT 85
That's incredible!
So many people seem to accept that owning a carbureted vehicle = hard cold starts. But that simply is not true. At least, it shouldn't be. As long as the choke is set up correctly and functioning, and the thermostatic air cleaner is in place and functioning, there shouldn't me *any* cold start problems or *any* problems driving in cold weather.
When they are set right, and all of the components are in place and functioning, there is very little difference between a vehicle with a carburetor compared to a vehicle with electronic fuel injection.
Old Jan 23, 2018 | 07:33 PM
  #30
willowbilly3
That's incredible!
In all my years in Alaska I saw very few efis that would start much colder than minus 30.
I had an old 83 Bronco with a 300-6. We had kind of quite using it but just kept it because it was so rusty it wasn't worth much and still ran good. It sat buried almost hood deep in a snow bank for a couple months. We had a spell where the high for the day didn't get above minus 52 for 3 days. I had dug out to the door and don't ask me why I even tried to start it but got in, remember is 50 below, it barely turned over but made about 2 revolutions and started up, and sat there and kept running. The power steering pump howled in protest though,lol.
So yeah, don't try to convince me efi start better that a well tuned carb engine.
