2012 F250 Cab mount pop TSB
I have read a few other threads about people with the same issue - pop under driver left foot from the cab mount. There is a TSB out for it so I know I am not going crazy. I have tried 3 different thickness shims with no luck ranging from 1/16" to 3/16" - even did all new OEM cab mounts all around. Every time I adjust the shim thicnkess and re-torque with loctite the noise goes away for about 50 miles them comes right back - more noticeable when its cold out.
My question is to the guys that have shimmed their front mount what thickness shims did you use?
TSB - https://static.nhtsa.gov/odi/tsbs/20...53418-5084.pdf
The following users liked this post:
sdiesel
27
10-20-2021 10:16 AM
the_old_ranger
13
02-02-2020 09:49 AM
pauls painting
05-29-2009 08:30 PM
