Early Bronco clutch linkage
Hi To all
I am putting together a basket case 67. It came with the original 3 speed and transfer case and was an originally a 289 truck which is missing. I happen to have the clutch equalizer bar from a 73-79 f150. It appears similar in pictures to what was used on the Bronco. Any idea if it will work on the early bronco?
Hi To all
I happen to have the clutch equalizer bar from a 73-79 F150. It appears similar in pictures to what was used on the Bronco.
No.
No.
1966/74 Bronco.
C6TZ-7528-J .. Clutch Equalizer Bar-Use with V8 engine / Obsolete
1966/77 Bronco.
Not only are the equalizer bars different (3 different types for 1973/79 F100/350's), but so are the inner/outer clutch pivots.
Plus...the clutch equalizer bar nylon bushings for 1966/77 Bronco are 3/4" O.D. while the F100/150's are 1.00" O.D.
Upper pic: 1966/72 Bronco // Lower pic: 1973/76 F100/350.
Basic part numbers are the same, but when the prefixes and suffixes are added to the basic numbers, that's what makes them specific.
Hi To all
https://seattle.craigslist.org/sno/p...406233754.html
sourcing clutch linkage prts
All that stuff (frame/motor brackets, bellcrank, spring) can B located at the typical bronk vendors (jeff's, Tom's, WH, Duff's)
Big Box stores (autozone, advance)
"For Sale" forums on bronk sites...
I may need the aftr mrkt bracket and bell crank to do my swap. I think it's WH that has 1 I can tack to the new 'sbf" bell.
