1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
my build thread: 1999 F250 XL 6.8L V10 5spd 4wd CCLB 238,000 miles
Old 12-25-2015, 08:27 PM
dwysywd's Avatar
dwysywd
dwysywd is offline
recent upgrades: New Warn Hubs, New Hercules 285/75R16 tires, couple of rear mud flaps, lo-profile tonneau, Dee-zee tailgate assist, Kwik Gate tail gate step, replaced rear door that was dented, upgraded gray vinyl benches to tan cloth buckets in front and cloth bench in rear and seat center flip up. (10) new coil packs and plugs. Heater core, serpentine belt, and finally, 4wd transfer case motor.
truck has zero rust, pretty good for 16 years old and 240k!
runs and drives like a champ.
this is my 5th Super Duty, my 2nd v10.
Old 12-25-2015, 08:29 PM
dwysywd's Avatar
dwysywd
dwysywd is offline
i will post a pic on this, but i am missing my passenger side sway bar mounting bracket. So i am looking to just replace all those parts I figured.
Old 12-25-2015, 09:57 PM
davester250's Avatar
davester250
davester250 is offline
It's the bolted-on part, right? If so, I'd just get it from a junkyard/pickapart place.
Old 12-26-2015, 06:50 AM
dwysywd's Avatar
dwysywd
dwysywd is offline
Thanks. That's what I wanted to hear. Just never had one missing like that before!
Old 12-29-2015, 09:19 PM
dwysywd's Avatar
dwysywd
dwysywd is offline
Update: built this for my bed lights, rear bumper lights, a 12v inverter I plan to install in the bed for the occasional power tool off the tailgate and a free line, Incase I want to add something like a rack light.
Old 12-29-2015, 09:40 PM
Mrbiscuits's Avatar
Mrbiscuits
Mrbiscuits is offline
No relays?
Old 12-29-2015, 10:37 PM
dwysywd's Avatar
dwysywd
dwysywd is offline
I'm running an LEd light in my bed and a few accessory switches. I just researched it and I can add it in. Just had not thought about. Kind of assumed I'd need a relay for things like air pump, winch, or other big accessory. Here the link I read on it. Thanks. http://www.therangerstation.com/tech...ry/relays.html
Old 12-29-2015, 11:06 PM
davester250
He may be assuming you are getting power from some switched source in the existing harness instead of directly from the battery.
But even from the battery, you don't want to be running high-current draws through those switches, they aren't designed for it.
Old 12-30-2015, 01:08 AM
dwysywd's Avatar
dwysywd
dwysywd is offline
Agreed. After I read the article I linked above, I updated my plans.
I'm not here to say I know it all...that's why I shared these plans. And sure enough, someone smelled a stinker. Glad its prewired and not a problem to fix.
Old 12-31-2015, 06:52 PM
dwysywd's Avatar
dwysywd
dwysywd is offline
Ok, NO RELAYS!!!!! So that was an EPIC waste of time. I spent all day watching videos, thinking I missed something! NOPE. I do not need a relay.
My LEDs for my bed, 3w at 12v is about 10A, and my switch is rated for 16A plus its fused from a panel, 10ga wire from the battery and 16ga wire for the switch running to the lights.
My 55w Hella back up lights are 15A, and according to EVERYTHING I read, you need to be considering a relay when the draw is greater 200w. So, I am stuck. I don't think I need a relay here either.
Finally, my last 2 switches are for a power inverter for my bed and a 12v lead for my trailer. Again, neither are running large power, I have 10ga from the wire from the battery to the fuse panel I put in. I have the appropriate fuses for the items. NO RELAYS NECESSARY as I see it.
Please, while I really appreciate the advice given, next time offer a little more than "why no relays" when asking what my usage and needs were. I am not upset by any means, but it was a big waste of time to research all this stuff for this project when in fact I didn't need them. NOW THAT BEING SAID, I know how to use relays for future projects and WILL MAKE SURE I incorporate them where necessary! FWIW, If I am wrong here on my calc/reasoning, PLEASE Explain so I can make the corrections.
Thanks again guys. Looks like I am all set. I will post photos once I get it all installed and working this weekend.
Old 12-31-2015, 07:25 PM
ligito's Avatar
ligito
ligito is offline
Having blown halogen light bulbs in the past, I will always use relays, for high draw items.
In one case, when the rpm dropped, the bulbs blew.
Bulbs aren't cheap, relays are.
Old 12-31-2015, 07:37 PM
dwysywd's Avatar
dwysywd
dwysywd is offline
Ok. Fair enough but I am using these only as back up/rear lights. If I need a relay then how should I insert into this setup? I don't mind adding one, but I everything I've read said I don't need them for this project.
Btw, please don't take my sarcasm for criticism. Just having some jesting fun. I really do appreciate all the insight.
Hella halogen 4.75" rubberized lights cost $5.99 from fleabay
Relay was $6.75.
Old 01-01-2016, 12:00 PM
dwysywd's Avatar
dwysywd
dwysywd is offline
They take longer, but I decided to wire relays. I already had them. And decided it was $5 worth of insurance for each item.
Old 01-19-2018, 07:06 AM
dwysywd's Avatar
dwysywd
dwysywd is offline
So update time:
253,000 miles
powder coated the aluminum factory wheels tan and took the steel wheels off. Kept the black plastic center caps.
Tinted the windows-all 6 😁
20% on 5 and 50% on the windshield
mounted some steps but frankly I mounted them too far forward. So I plan to move them back a foot.
Added the square 2008+ mirrors. (Not in current photo. But will get new photo loaded this weekend)
Added a MOVE bumper kit to the front as well. And painted the grill and headlight surrounds when I painted the bumper.
And because the truck rick had no rust, I took advantage of that and undercoated it this past summer.
Mechanically, it has been really sound. Replaced wheel bearings and bushings on the front along with drop link bars and bushings.
Old 01-20-2018, 10:20 PM
Sdowdle541's Avatar
Sdowdle541
Sdowdle541 is offline
The wheels look pretty cool!
Quick Reply: my build thread: 1999 F250 XL 6.8L V10 5spd 4wd CCLB 238,000 miles
