4x4 VS 4x2... What is turning?
i bet it spins very little. only a fraction of revolutions in relation to the vehicle speed. maybe ill be proven wrong but when i get a chance ill mount a gopro to see what happens as ive got acess to a couple different type of cad trucks. to avoid any back peddling later, is your position that the front drive shaft will turn in similar revoluton with vehicle speed ? half, qaurter vehicle speed ? one revolution per mile ?
Last time Dodge had a good 4x4 setup was in 1993, with the kingpin Dana 60's.
The current AAM 9.25 is junk, from the disconnecting means to the ball joint geometry. The spider gears now continuously rotate instead of the entire carrier, and as many know, those are a plain bearing design. The truck has a plastic actuator housing that's on the tube; easily damaged. Only the lower ball joint supports the weight of the entire truck, ball joints also cycle differently. It truly is a crap-tastic axle. Very little aftermarket support unlike the Dana 60 found under the Super Duty. Wheel bearings are 20% smaller than the Ford units, even on the 'mighty' Ram 5500 trucks.
The copycat design of Ford's three link is also crap, do me a favor and crawl under a 2013+ Ram and take a look at the track bar frame mount. It's about five pieces of sheet steel welded together with not very much bracing, it also isn't easily replaceable like the bolt on Ford unit.
This and the fact the entire truck is built in Mexico is why I won't own a Ram.
I can admit when I'm wrong. No worries. Do it. Record 10 miles at 80mph. I'll bet it spins significantly, just like my Jeep YJ did.
I'm not one of the normal truck chumps with Ego issues. If I'm wrong about this, I'm cool with that.
For a period of time, Dodges front axle came right off an assembly line right next to the Fords far superior front axle. I just wanted to scream in disgust. There's no excuse for Dodges lack of foresight, other than trying to appease marketing and low information truck shoppers that don't want to get out and touch the front axle ever.
im glad you brought up crap-tastic junk because its a subject I have some experience in. years ago I had the misfortune of owning a '89 f250 4x4. what a complete pile of crap those trucks were. perhaps the very definition of crap. with its scissor front axle (need I say more), its zf 5sp trans that went through synchros like water and its fuel system that used 2 fuel pumps. likely there was more ccrap-tastic features of that truck but ive tried to wash my brain of all memory of it. the only good thing about the truck ( besides the day I got rid of it and never had to see it again) was that it didn't use reverse thread lug nuts on one side of the truck like some of the other ford trucks of that era. I still recall the first time I encountered fords reverse thread lugs, i asked my dad WTF is this and he replied ;son that's one of fords many brilliant ideas;. I wonder if that engineer is still on fords payroll LOL
im 100% confident ford has every bit as much crap-tastic junk engineered into their trucks over the years as gm and dodge
ive read nearly every thread on this site in the 17+ SD section and nothing has convinced me these trucks are in anyway better than other new trucks on the road today. more cameras... sure. larger sunroof.. probly. seats that vibrate better... perhaps. better truck... nah I don't see it
and to think ford rode that tti horse out for 19yrs or so ?
its been nearly 15yrs since I had that '89. if I knew then what I know now...
There are still people over at Expeditionportal that love the TTI. I just roll my eyes at them.
I could just lock one hub on my F350 work truck. That would be similar to the Dodge setup. Will the diff, just diff out continuously? Or will force get transfered to the carrier, and the drive shaft eventually start spinning? I think I'll try a zip tie, I don't want my gopro getting eaten by snow. I'd like to wait until the ground is dry to roll under the truck, at least.
However, when it comes to 4x4 running gear, the current SD blows the Ram offering out of the water, and has done that for the past 15+ years since Ram went to AAM.
I've lived three miles down un-maintained dirt roads for the past 30 years, and I can easily tell you what brand holds up best, and it certainly isn't a Ram truck.
#28
I agree the TTB wasn't the greatest, horrible to try an keep alignment.
oh ya one more thing before i say adios, other day i was watching 4x4 truck pulling league and 90% of them were using cummins engines. shocked the hek outta me since powerstroke is supposed to be such a brute. i guess not when it comes to competion pulling
#29
sorry i just dont see it your way but for argument sake we'll agree to disagree and you can get back to kissing you clunky vacuum hub, death wobbling, driveline vibrating... err i mean far superior running gear. good day sir
#30
Have you talked to those guys? Comp pulling is on average, on a 3rd grade intelligence level, with some decent mechanical skills and way too much money. If you want to use that to reinforce your decisions, so be it. But LOlz, are you for real man? (and the Dodge front axle still sucks, and Dodge should be ashamed, anyone that recommends that axle: Shame, Shame.)
