Both driver's and passenger's windows leak on my '71. They are noisy at highway speed, and allow a little moisture to come in when I wash it. The gaskets feel dry and brittle, so I'm assuming I need to replace all of them (although the vent windows seem fine).
mountainrev i would try SteeleRubber.com. i just replaced the rear window gasket today on my 67 f-100. it fits awesome. 5x on what orich says about LMC. imo. only use them if you can,t find it anywhere else.
This is my hard luck story with window channel gaskets:
I replaced then
m with aftermarket stuff a year ago. It didn't do a bit of good on the driver's side. I found that the window rattled to and fro. It turns out that the glass had been busted out before I got the thing and the glass cutter cut about 1/4 inch too narrow.
My luck.
I checked the prices on Steel Rubber. WOW! I thought D.C. was high. There is no way their quality is high enough to justify those kinds of prices. I'll stay with Dennis Carpenter.
Steele Rubber is made in the US and is some of the highest quality. Not sure if it's worth as much as it costs, but I have seen and touched their products and they are fantastic.
NumberDummy i was on the D.C. web site today. the only thing they have listed of the 67/72 f-100,s are door anti- rattlers. NPD also does not have kits to do the doors. Mac,s does have a kit listed on their web site. not sure where they are made. it may cost a bunch but i am going to use Steele Rubber on my 67. i only want to do this once.
NumberDummy i was on the D.C. web site today. the only thing they have listed of the 67/72 f-100]s are door anti- rattlers.
Open your peepers.
1/10/2018 @ 3:18 PM PST .. I didn't have any trouble finding any of the 1967/72 F100/350 cab/door weatherstrips at dennis-carpenter.com, so you shouldn't either.
If you don't see 'em, call DC and ask: 800-476-9653.
NumberDummy i did open my peepers. the only thing listed was the anti- rattler kits. i clicked on all of the other parts that where in the listing and nothing came up. i am going with Steele Rubber anyway.
Here DC window shield gasket coming apart at it's joint, along with their door window Anti rattle fuzzy strips in place take note the ends lengths?,
plus their vent wing gasket seal not wide enough an had to touch up the paint from old paint showing where gasket did not cover like the oe did why.
I called DC at the time due to the hood lip trim was a half inch to long and could not install it, sent it back.
I complained that their QC manager must have been sleeping on the job. The gal on the phone at DC said they don't have any QC manger. I told her this must be why this hood trim is to long. A new window shield gasket was sent to me free.
I don't know who to really buy from now since DC IS SUPPOSE TO BE the best stuff made from FORD Dies spics.
In addition to what you found, I found the door weatherstrips (DC: C7TZ-8120530-PR), vent window seals (DC: C7TZ-8121448-PR), front and rear back glass weatherstrips (there are two different types of each).
In addition to what you found, I found the door weatherstrips (DC: C7TZ-8120530-<acronym title="Page Ranking">PR</acronym>), vent window seals (DC: C7TZ-8121448-<acronym title="Page Ranking">PR</acronym>), front and rear back glass weatherstrips (there are two different types of each).
I found those as well. But what I'm not finding (and neither is @ lilorbie) are the upper window gaskets. Dennis Carpenter lists the complete window gaskets (incl. anti-rattler and upper gaskets) in the 2017 print catalog that I have, but not online. All they have is the anti-rattler (C7TZ-8121452-PR). Since the upper gaskets are brittle on mine, I believe I need to replace them as well as the lower anti-rattle felt gasket. I haven't called DC, so I guess I should probably do that next. Otherwise, as stated in my OP, I'm thinking of going with the Rock Auto kit (http://www.rockauto.com/en/moreinfo....sn=452&jsn=452), even though it is most likely Chinese. Can't see spending what Steele Rubber wants for their kit!
