335 / cleveland heads ?
I am looking to clarify the 351C's cylinder heads . I thought I had 351M / 400 heads on a 400 engine block . Finally double checking I see the " 2 '' script in the corners ? 2 and 4 script heads were only used on 351 Cleveland engines , right ? So the block these heads came off should be pure 351 C
351c 2v heads are the same on 351m and 400 engine. no 351m or 400 were built with 351c 4v heads from the factory. it dosent mean they didnt fit. same bolt pattern.
he have 4 or 5 kind of heads you can bolt on a 351c. from 70-74 351c US ford produce 4 kind. in australia they produce a mix from 4v and 2 v heads. not available in US. they call them aussie heads. australian took the closed head chamber design from the 4v US and cast them with the intake and exhaust design from the 2v US heads. if you have a 351c with 2v heads its not rare. same as 351m/400.
tried to find build casting ##'s ,are non I can see on the heads other than a short 4B27 one head and the other has possible 3F12 , that ones hard to read . These heads were removed off the possible 351c block that is still in a old ranchero . They weren't cc checked but are going to be . Suspect there in the 70cc range being from a 1974 year car .
What I have read is 351M ' and 400's didn't come with 2 or 4 bbl script heads . Not saying they wont work on the 400 . I will be surprised if that old rust bucket had a Cleveland .
You have Cleveland heads, 2v, open chamber. If there's no little raised circular "bump" next to the 2 then they are closed chamber 2v heads. Those heads will help raise the compression ratio.....trouble these days with the junk fuel we have. Still, they're desirable heads. A 'bump' beside the 2 means they're open chamber heads.
351M/400 heads would have an 'M' stamped in the upper corner. The vast majority of M Block heads have this although a few don't have any markings.
Cleveland heads could have a 2 or a 4 stamp, with or without the raised half moon "bump."
Heads
Valve seats
that seat inserts are totally unnecessary, because 90% of the heads that are reconditioned don't get seat inserts. The heads in the picture with the layout dye on them got exhaust inserts, not because of the hard surface being ground through but because three of the eight had cracks in them.
Not true. If that were the case every single cast iron Ford head would require seat inserts when it was reconditioned. The factory hardening is plenty deep enough to support at least one regrind without going through. But on the other hand if what you say is true that would prove conclusively
