37’s only 55 lbs. Pro Comp AT Sport 37x12.50r20
Been doing some research on 37’s and ran across the Pro Comp AT Sport tires in 37x12.50r20. Specs say it’s only 11.8 inches wide so should eliminate any rubbing issues on stock wheels vs a true 12.50 tire. But what has me interested is that these tires only weigh 55 lbs (as per Amazon and other websites). This is 3 lbs. lighter than the OEM factory tire. Also read on Summit Racing website that this is a 3-ply tire which would explain the low weight. It also appears that Cooper Tires makes the Pro Comp tires. Has anyone ran these tires? Not too popular but I don’t tow so and do all pavement driving which would make the softer 3 ply tire a good option.
