Inherited an 1986 F150 300-3 SPEED
I inherited my Uncles 1986 F-150, 300 INLINE 6,3 SPEED in the floor, SWB 80,000 original miles ...Im wanting to clean it up , do some maintenance on it and pass it on to my 15 year old when he turns 16 in April ..I'm worried about him learning to drive the three speed ..If I was to convert it over to an AOD transmission would that be possible ?... Thanks in advance
Why not teach him how to drive stick?
Once he learns he can then drive any thing stick.
I had to take my license test on a stick, 68 Dodge panel van with camper top so you could stand up inside. It had a 3 on the tree.
All I had to do was drive around the block and park it and got my license.
I now drive trailer trucks and was talking to a fellow worker and he said he could not drive stick and why his truck is an auto.
Dave - - - -
Dave - - - -
Dave - - - -
Dave - - - -
I second that.
Teach him to drive a stick, once he learns that he's half way to being able to drive anything on the planet.
Not only that it will slow him down and not allow him to be as stupid behind the wheel like an auto will or like most all teenagers can be.
Yes I have been there and wear the shirt!
You could do an aftermarket AC unit in the truck.
I am going to guess your son will want AC too.
Dave - - - -
Vintage Air I believe has a full kit for it.
If you're worried about the column shift, you can swap it to an M5OD and gain a better gear spread and overdrive. However, the column shifts are very cool, and were uncommon to start with on this generation. My son drove my truck while he had his permit (4 speed granny) and really enjoys it now
Several generations of us learned to drive on stickshifts. 3 and 4 speeds. Your kid is made out of the same stuff as we were. The younger you can start them the better. My dad started me steering when I was 3 and I could drive a stick in first grade and I started my nephew when he was 3, setting on my lap and steering. He also could drive my 59 Belair with a 3 on the tree by the time he was in first grade.
