Sponsored by: Auxito
Need help fast
Old Jan 6, 2018 | 11:47 AM
WaltLee's Avatar
WaltLee
Need help fast
Changed plugs, wires, coil on sons 2002 F150, 4.2, while home for Christmas from school. Everything fine until this AM. Started truck - white smoke, rattling sound in engine. Pulled 4 of 6 plugs, all looked like they had oil on them. ???????
Old Jan 6, 2018 | 01:10 PM
alloro's Avatar
alloro
Sounds like mechanical damage. Did you verify that the correct plugs went back in or that nothing broke off any of the old ones and fell into the cylinder?
Old Jan 6, 2018 | 04:24 PM
WaltLee's Avatar
WaltLee
Yes, everything was same oem as previously installed. Pulled plugs, all have antifreeze residue, smell antifreeze at tail pipe. Know for sure there is probably an intake gasket at least but the knocking is what I can't figure out.
Old Jan 7, 2018 | 09:10 AM
alloro's Avatar
alloro
FYI, if you have antifreeze in the cylinder it can also be a head gasket. The knocking could be from higher cylinder PSI due to fluid being in them, kind of like ignition detonation...just a thought.
Old Jan 8, 2018 | 05:29 PM
WaltLee's Avatar
WaltLee
Intake gasket blown, connecting rod broken....after some research this is apparently an issue with original intake gaskets....replacing motor.
reyjav
1997 - 2003 F150
Jan 26, 2011 08:23 PM
rivenray
Modular V8 (4.6L, 5.4L)
19
Dec 4, 2004 12:56 PM
Mac 25
Aug 29, 2004 09:29 PM
mariocruz76
1983 - 2012 Ranger & B-Series
Aug 19, 2003 09:05 AM
dfawvor
Aug 1, 2003 05:47 PM
