Sponsored by: Auxito
Fuel injectors??
Old Jan 3, 2018 | 03:27 PM
stvMo's Avatar
stvMo
Fuel injectors??
Anyone use any of the rebuilt injectors out there? New ones are any where from 40 to 60 dollars each and was going to change all 8 of mine.
I've seen some for $150.00 all and others for as mach as $480.00.
I'm not rich but don't want to put in something that is going to go bad in a month...
This is for a 2003 F150 5.4..
Thnx
Old Jan 3, 2018 | 08:41 PM
Bluegrass 7's Avatar
Bluegrass 7
What is leading you to changing any of them?
Good luck.
Old Jan 4, 2018 | 08:59 AM
stvMo's Avatar
stvMo
Been getting P0300 code and longer crank times to start. O2 sensor reading lean...
I replace plugs and coils 6 months ago. O2 sensors a couple months ago....
So I think I have a couple with low pressure or partially clogged...
Old Jan 4, 2018 | 11:50 AM
Lime1GT's Avatar
Lime1GT
I think I'd be checking for a vacuum leak at intake manifold area or air getting past the MAF sensor, like cracked or loose air inlet hose. Also an EGR valve stuck open.
a vacuum leak in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open.
Old Jan 4, 2018 | 06:07 PM
Chad T. Keogh's Avatar
Chad T. Keogh
I would also try a good injector flush before replacing them. Might be just a little dirty.
Old Jan 4, 2018 | 06:31 PM
pdqford's Avatar
pdqford
And how is the fuel pump pressure and the fuel filter?
And when it throws the P0300 does the freeze frame data indicate low engine load or high engine load?
Dustin Myers
2004 - 2008 F150
Dec 2, 2017 08:13 PM
Skullver
2004 - 2008 F150
May 17, 2012 07:58 PM
jwsch
1997 - 2003 F150
May 25, 2011 11:55 AM
FordMan190
1983 - 2012 Ranger & B-Series
13
Aug 22, 2005 12:42 PM
Deebo78
1978 - 1996 Big Bronco
Jan 23, 2004 09:54 PM
