Adjustable class V ball mount
Old Jan 2, 2018 | 08:13 AM
Justa02TJ's Avatar
Justa02TJ
I am tired of having a collection of ball mounts that I seem to always be swapping out for the trailers I have.
Looking at the Curt 6” adjustable class V and the Bulletproof 6” adjustable class V. Curt is ~$220 (etrailer) and the Bulletproof ~$299 (Direct). Minor differences like the 2” ball on the Curt is only rated for 10k as the Bulletproof is rated at 12k. The 2 5/16 Bulletproof ball is rated a bit more than the Curt too. Other than that they are very similar.
Does anyone know of a coupon code for the Bulletproof mount to save a couple of $s or is it that much nicer/better than the Curt?
Experiences?
Thanks in advance,
Mike
Old Jan 2, 2018 | 08:38 AM
HRTKD's Avatar
HRTKD
Check out the Weigh Safe ball mount. There is a thread around here somewhere with a coupon code.
Old Jan 2, 2018 | 09:33 AM
ccie7879's Avatar
ccie7879
I bought and like the GEN Y Hitch. It doubles as a pintle, and the adjustment slots can accommodate a standard ball mount you already have. If for example you want the trailer back a few inches so the tail gate clears the jack handle you could use your stand drop mount in any slot. They are rated for 21K or 32K with the 2 1/2" or 3" version. The adjustment slots are the same size as the part that goes in the truck receiver.
Old Jan 3, 2018 | 08:17 AM
Justa02TJ's Avatar
Justa02TJ
I checked out and like the Weigh Safe hitch, but the 2” ball maxes out at 8k. Not bad but others are 10k and 12k which gives a bit more cushion.
Old Jan 3, 2018 | 08:19 AM
Justa02TJ's Avatar
Justa02TJ
I forgot about the GEN Y. I will check them out. But what I remember they are big $s.
Mike
Old Jan 3, 2018 | 09:48 AM
TufLuk13's Avatar
TufLuk13
I have the bulletproof hitch. I love it. Bulletproof actually makes a 6" drop that tows up to 30k. I believe all their hitches are 22k and up. Easy to use, super heavy duty, looks great. I'd buy again without hesitation. Yeah its expensive but so was your truck.
SDTruckMan
Mar 20, 2019 11:08 PM
mrichied
2015 - 2020 F150
Jan 16, 2018 06:08 PM
347Flatty
Oct 6, 2017 02:34 PM
351Cleveland C4
All Things Towing
Jan 22, 2016 07:48 PM
Supercab
All Things Towing
Apr 28, 2012 05:16 PM
