def in fuel
Can someone explain to me how the entire fuel system (including injectors) can be contaminated with the engine in idle for less than 30 seconds. How can the DEF get through two filters and two pumps to an injector so quickly? The Ford dealer claims the entire fuel system is trashed about $10k to repair. Do they have a scam going on here? Do I smell a rat?
because the fuel system is a closed loop system. The unused fuel gets returned to the tank.
The fear of def circulating is too great. Even for 30 seconds of idle time.
Ford has determined the best practice is to do a complete replacement.
Now you can gamble and drop the tank, clean and put in good fuel, change your filters and hope for the best, but ford will not warranty fuel related items in the future and furthermore, this may not even work.
Purge the lines as well since after cleaning the tank and changing filters, there will be a little DEF remaining. It's more than a few drops that the DFCM would normally filter out.
Our company had an F-350 get bad fuel two years ago or so and it was $9k to clean out the mess and replace the failed HPFP. The recirculating system is why metal bits ends up everywhere.
If the HPFP grenades at some point, I think the only additional step is replacing injectors due to metal contamination in the system vs now would avoid that step. Since it's a huge cost, I agree with the others to put in the effort cleaning out the fuel system the best you can. Drain the DFCM often for the next tank or two and probably change the fuel filters again soon. After that, all you can do is keep driving it and hope you win. Set the repair cost to the side, it could be six weeks or a year. Or never and in that case $10k to put towards a new one.
Being a 2011 like mine, you don't have a warranty anyways.
Also depends on how much fuel you had in your tank when it was pumped in. The sending unit draws from the bottom so if you were half full or more it's less likely it circulated. Flush all the lines, clean the tank, and swap the fuel filters and I'll bet you'll be fine. May have to replace the driver side fuel rail since it has a couple sensors that could of gotten some def in them. Use a good lubricant for now on and good luck. If it is contaminated claim it on your insurance and just pay the deductible.
Since DEF is mostly water - have you tried draining some fuel out of the chassis mounted fuel filter, let it sit and see if there is "water" in your fuel? even if there is "some" I'm thinking that thing is supposed to "catch" the water before it circulates through the system. Is it 100% fool proof? Don't know. If there is no "water" in your fuel after you drain some out of the filter I would totally clean everything out before spending 10k.
What to do
Do not drive it anymore. Tow it or drop the tank and clean the lines yourself. Replace the filters now, and in 2 month pull the lower filter and check for metal bits in the filter. Add a lubricity package to the fuel after you fill the tank with good diesel.
Many have done the same thing. If you have a problem shop the repair price. Ford makes a HPFS kit with new everything, get this kit if need to. I think you are out of ford warranty so you have no reason to pay dealer prices.
