2003 Eddie Bauer Coolant temp
Old Dec 30, 2017 | 05:50 PM
pablocruz69's Avatar
pablocruz69
I have a 2003 Eddie Bauer 5.4, over the last few days the temp gauge is only marking about 20-25% and the heater is blowing warm air (this is more noticeable on cold days, about 32 degrees outside) on warmer days 40-45 degrees the temp gauge goes about half way and the heater blows out hot air, like normal. Yes there is coolant and I have the climate control turned up to high (90 degrees). Disclosure, while I was checking the coolant level I did notice a little bit of coolant that was pooled around the #1 fuel injector area. I am pretty sure there is a leak, but I couldn't find where it was coming from. Maybe there is air getting into the system causing this issue?
Old Dec 31, 2017 | 09:45 AM
alloro's Avatar
alloro
Your thermostat is stuck open.
Old Jan 4, 2018 | 05:20 PM
pablocruz69
As usual Alloro you nailed it!! Thank you, changed the thermostat and the temp is normal and the heat is nice and toasty!! Thank you!!
jggearhead
6.7L Power Stroke Diesel
Sep 27, 2016 07:41 PM
billbot
Jul 8, 2012 08:48 PM
Blakeb4988
Sep 23, 2010 05:09 PM
learmoia
Dec 29, 2006 10:16 PM
fr87hn
23
Apr 2, 2006 07:24 AM
