I Used To Brag On My Dealership.....
I don't trust anyone to treat my truck as good as I do, so I perform my own oil changes. I read where these oil change places don't realize you have to wait at least 15 minutes with the EB engines, and they overfill them often. Also, dealerships use bulk oil and I don't trust bulk oil. I use Pennzoil Platinum Ultra fully synthetic and wouldn't use anything else. Warranty work is the only reason I would go to the dealership at this point. I know there are very good ones out there, but it's just a trust issue with me.
I don't think there is any bulk oil that any dealership uses that is as good as what I use. I know that is up for debate, but that's my thoughts on it. Dealerships don't use the best premium oil that is available, because it would affect their profit margin. Of course they are going to go the cheapest route available. It's as much a peace of mind thing as anything else I guess. I know more expensive is not always better, but the research that I have done says that Pennzoil platinum plus fully synthetic (made from natural gas) is the best. Yeah, I know that may not be the case, but it's good enough for me.
I use Pennzoil Platinum too. Have for years since the guys at BITOG like it so much. But Motorcraft synthetic blend is held in high regard too. Most oils these days are good. But you are probably right about them stocking the lowest cost oil. My biggest concern would be getting 5w20 put in. From some posts I've read at BITOG, improper spec oil is put in more often than you would think.
I had my IWE and hub (both destroyed because they couldn't get me in for weeks) on the drivers side replaced about a month ago. I asked how the vacuum system tested, the tech said "we didn't test anything". They claim the IWE failed not a vacuum issue. Well guess what's grinding again... Of course it's not doing it all the time so i guess ill baby it until it gets worse and have them fix it again, hopefully it won't take 2 weeks this time.
I've always wondered about bulk oil myself. I was never sure if rumors are true but I've heard that bulk oil is reprocessed used oil. Of course someone is going to say, "no it's not." If there's no difference in the bulk oil that Ford dealers use and the engine oil that comes in quart Motorcraft labled containers then why do they stock both. Just curious here. No argument from me because I don't know.
I guess it shouldn't matter as long as the oil meets Ford specifications.
Had it out with the dealership GM yesterday over the complaint I had. I went in to ask what they were going to do about the front-end alignment of my steering wheel. After they decided to send me to another shop for a correct alignment I commented, "why didn't they do that in the beginning knowing the alignment machine wasn't working right." The GM replied, "We're not perfect, what do you what me to do, fire the guy?"
That's not exactly the diplomacy I was expected. Oh well!
Well. I deal directly with the delivery guy for the bulk oil. He tells me that the oil is FRESH, NOT recycled oil. We sell oil in bulk, and our lube guy, can set the amount of oil down to the 10th of a quart. I fill out the lube tickets myself, and list the oil down to the exact amount that FORD says. I do it everyday.
So............................. I don't know what else to say.
#28
#29
#30
