Engine ID
Old Sep 13, 2003 | 12:05 PM
CCampbell's Avatar
CCampbell
Engine ID
Is there an easy way to ID an engine CID?? I have a 69 F-100 and the guy I bought it from says it's a 390.....I just wanted to be sure?? Any way to verify that??
Old Sep 13, 2003 | 04:16 PM
banjopicker66's Avatar
banjopicker66
Engine ID
You have 2 possibilities for original engine: 360 and 390. Be advised that most FE motors magically join Cinderella and turn into 390s on sale day. Unfortunately, they re-pumpkin themselves back into 360s (or 352s) the day after. You'll need to check the stroke to make sure.
Here's the easy way to check the stroke without removing the head. Get a straight 12 inch piece of white electrical house wire or coat hanger wire. Get a magic marker. Remove the number 1 and number 8 spark plugs. Turn the engine over until the timing mark is at TDC. Put the wire in the number 1 spark plug hole with wire resting on the top of the piston. Make a mark on the wire even with the lip on the valve cover. Now move the wire over to the number 8 cylinder and mark the wire again, at the lip. Measure the distance between the two marks.
For those that don't know: 3.98 is the stroke for the 410 and 428 engines; 3.78 is the stroke for the 390, 406 and 427 engines and 3.5 is the stroke for the 352 and 360 engines.
Do if you have a stroke of about 3.75 inches, you have a 390. If it is 3.5, you have either a 352 or a 360.
Most likely, if the engine is original, you have a 360.
Old Sep 13, 2003 | 05:29 PM
Matts72's Avatar
Matts72
Engine ID
You could just look at the VIN code and post it here, somebody will be able to tell.
Old Sep 13, 2003 | 06:40 PM
2tweak's Avatar
2tweak
Engine ID
Look under the starter and give us the casting codes you could give us the codes on the heads (in the middle under the exhust manifold) but thet could from many different motors
