Removed headliner to reveal mouse nest
Rust and paint question: I was not planning on getting anything inside the cab painted but should I have the area under the headliner painted. There is some peeling paint and some rust. Especially where the nest was stuck to the roof. What should be done to the underside of the roof? Just primer or primer and meadow Green?
Received 4,135 Likes
on
If I owned a 53 or 54 Deluxe Cab or a 55 or 56 Custom Cab, I'd be really ticked because no one makes the correct headliner for those cabs. The center section was perforated. The Ford publications of that day called it the thermo-acoustic headliner. It came with 1.5 inches of fiberglass insulation above it.
It measures 18 x 39 for $11.75 with free shipping. I'll have to figure out how much I'd need for the roof. If it is water proof I'll put some inside my doors too.
Hey Abe,
Did you check to see if you had a live one in there? That's about the
most comfortable looking mouse nest I've ever seen... You even got it
out with the entrance still intact!
I feel lazy watching you do the roof. Some previous owner had taken down
all the interior roof structure on our truck... no hooks... no metal piece spanning
the cab like you have.. I just sprayed rhino liner to get done. Now I have to circle
back to do it right so I don't get Abe shamed.
Looking good in Pennsylvania... I don't know how you do it. I looked at the weather
forecast up there for the week.. It looks brutal.
Ben in Austin
1950 F1
Ben in Austin
1950 F1
18 years ago I put some kind of foil faced insulation in my 54 roof with adhesive spray and it is still holding as far as I can tell.
#28
#30
