E4OD normal press.
Old Sep 13, 2003 | 11:35 AM
javi2001's Avatar
javi2001
Post E4OD normal press.
Hi all, I'm about to install a rebuilt E4OD 91' to my actual F150 1986, Iwant to know wich are normal pressures for this trany and the procedure to doit, my experience is on AOD tranny only.
Any imput will be appreciated.
Reagrds,
Old Sep 15, 2003 | 03:39 PM
Kevin Duffy's Avatar
Kevin Duffy
E4OD normal press.
Did you do a search and look around?
We need to know something first. What kind of engine is in your 86' f150? Im no expert on this. But your torque converter and flex plate will have to have the same bolt patern for it to even bolt up. Do you have the kick down linkage for the new 91' trans? You also have to worry about transmission to trans tunnel clearance, trans cross member, drive shaft length. For a pressure number, the new trans will operate at what ever pressure it wants to I guess. If it was rebuilt to stock. Hope this helps.
Old Sep 18, 2003 | 08:43 AM
javi2001's Avatar
javi2001
E4OD normal press.
Well, the trany is going to be bolted on a 6I engine 300CID, carby, i got used drive shafts.
I need the presures to be sure everithing is ok
