Critique of first patch panel
Old Dec 27, 2017 | 11:57 AM
3twinridges's Avatar
3twinridges
Originally Posted by Stephen67
Check your gas, that usually happens when it gets low, is set too low, or a fan blows it out. Nozzle might need to be cleaned out too.
Right on, I was out of gas! Sure my nozzle needs cleaned, picked up gel today. JB
Old Jan 2, 2018 | 11:18 AM
Carbonarc's Avatar
Carbonarc
Originally Posted by 3twinridges
Shrinking disc on an angle grinder and a wet rag. JB
JB, thanks for the heads-up on shrinking disks. I didn't know about them, fair to say I have a long way to go and a lot to learn on this project. Curt
Old Jan 2, 2018 | 12:22 PM
3twinridges
It's easy to see a high spot and get after it with a hammer /dolly. Before you know it now you have a low. And when you hit the low back up it was higher than before or even worse it's caused an adjacent area to be high. Dang.......
thats when I break out my shrink disc and fix my highs. For some reason it's hard to remember light taps and the phrase bumping metal, for me. Metal working takes time, something isn't accomplished with just a few whacks with a body hammer. That I am learning.
JB
Old Jan 2, 2018 | 01:11 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Congratulations on your progress, its obvious that you have listened to and applied the advice from other members and it really shows. Yours looks better than my first patch for sure, and you will improve with each one. Keep up the good work, its inspiring, and will help others that maybe a little hesitant to try it on there own trucks. Keep on Rockin On.
Old Jan 2, 2018 | 01:56 PM
tnunisaw's Avatar
tnunisaw
I think I would try to clean up the old metal I'm welding the patch to. Looks pretty rough. Wire wheel, flap disk or even a small sand blaster. Cleanliness leads to a better weld.
dschr60
Feb 11, 2019 06:09 PM
xXANBXx
Feb 10, 2018 07:37 PM
bobj49f2
Dec 22, 2016 08:24 PM
superdave02f552
Aug 28, 2014 06:30 PM
codys50ford
Oct 1, 2007 10:40 AM
