Auxiliary Leaf Spring Considerations
Old Dec 20, 2017 | 02:29 PM
flowney's Avatar
flowney
My '76 F-150 4X2 LWB truck has an auxiliary leaf spring that looks like this:
... but my '76 F-100 4X2 LWB truck does not. I'm assuming that this difference is part of what justified the F-150's higher GVWR which, in turn, justified emissions and other exemptions for the F-150 that the F-100 didn't get.
From the looks of it, this aux leaf does nothing until the load gets pretty high so I'm wondering about whether it is really necessary for my purposes. This F-150 has an older Class V Draw-Tite hitch with a 2" receiver. My 18' dual axle trailer uses a 2.5" ball and would probably never pull more than 5K pounds.
So what things should one consider before removing it?
  • At what trailer and tongue weights does it kick in?
  • Is it better to leave it in if other, fully active leaves are removed for a softer ride?
  • How does this aux leaf interact with common lowering techniques?
  • How does it interact with traction bars, Cal Tracks and the like?
Old Dec 20, 2017 | 03:20 PM
JakeHan's Avatar
JakeHan
1. No idea, depends on where the load is (weight in the bed, hitch weight, etc.)
2. I'd say that's a good plan, if you're shooting for stock height, and is more/less the idea behind them. If you built up a stock pack to carry the weight, they'd be REALLY stiff empty. One thing to watch, though, is that the clearance from the overload to the hangers stays the same as you drop leafs from the main pack - otherwise, you get close enough that they bang every time you hit a bump.
3. Lowering would be the same issues as above, they get too close to engagement so any suspension travel will cause a bang and a bounce. The other issue would be an angle change, say you changed rear shackles and changed the level orientation, one end would contact too soon.
4. would think it'd be okay with traction bars......
Old Dec 20, 2017 | 05:35 PM
flowney's Avatar
flowney
Correction
Mine is actually a Class III hitch. not a Class V hitch. The sticker had (V-5) on it as shown here:
... which faked me out but the specs are for Class III as per Wikipedia.
What a great hobby. I learn something every day.
Old Dec 21, 2017 | 10:31 AM
flowney's Avatar
flowney
Thanks for the reply Jake. I think that hitch/tongue weight would be where I apply the greatest stress. A two axle trailer with a 5,000 lb. load wouldn't apply that much weight to the truck, no?
Using the trailer scenario above, I wonder if the aux leaf will ever get used.
Makes sense and seems to argue for removing the aux leaf should lowering be attempted. I'm thinking of DJM shackles or, more radically, an axle flip.
Ditto for anti-sway bars too I'd suppose.
Old Dec 21, 2017 | 02:43 PM
JakeHan's Avatar
JakeHan
Sway bars should be fine with 'em, have a 250 with both from the factory. As long as everything clears physically, which it should, they have different functions that don't really interfere.
As far as the trailer weight, you'll be 400-600# or so at the tongue? Since you've got a lever-effect, it's compounded at the axle by a factor of roughly 1.5, if I remember right, so you could guess maybe 1000#
Trying to guess spring rates when "customizing" packs is pretty tough - unless it's an engineered and tested spring pack it's pretty much all guesswork at how much squat you'll get at load, etc. Years ago, we did a lot of that stuff at my "college" job, working at a trailer sales place. When dealing with lowered vehicles, the fallback was aux. airbags or Timbrens, that way you had a safety factor to keep from bottoming out without having to really engineer a whole new spring pack.
Old Dec 21, 2017 | 04:48 PM
flowney's Avatar
flowney
Thanks. This all helps reduce the number of things to experiment with. Ultimately, experimentation is what will tell the tale here.
EB-Larry
2015 - 2020 F150
27
Apr 8, 2018 05:09 PM
Big_Daddy_O
6.2L V8
Aug 14, 2013 10:04 PM
MoyockPowerstroke
Mar 10, 2010 10:00 AM
Dave88LX
Jun 14, 2004 12:51 AM
sprintcarcrazy
2004 - 2008 F150
Apr 8, 2004 05:22 PM
