Engine changes to 2018 - Are there any?
Old Dec 19, 2017 | 11:24 AM
BIGTRUCKBIGRV's Avatar
BIGTRUCKBIGRV
So, apparently the rumor that Ford changed the Heads on the 2018 6.7L are incorrect (As a tech looked up the 2017 and 2018 part numbers and both were apparently the same). Are there any changes that anyone is aware of that would point away from the 2017 trucks possibly being able to be software updated to 2018 HP and TQ numbers?
This is would great. I know the numbers are marginally better (probably not enough to matter), but it would be a good thing if Ford did a simple software upgrade to 2017 owner's trucks as part of a TSB.
Old Dec 19, 2017 | 12:50 PM
PapaDon's Avatar
PapaDon
Good question
....following.
Old Dec 19, 2017 | 12:54 PM
wfedwar's Avatar
wfedwar
Seems like wishful thinking that Ford would update the EEC to give 2017s a bump to 2018 performance.
Old Dec 19, 2017 | 12:59 PM
shawnw17's Avatar
shawnw17
They did it with the previous generation trucks.
Old Dec 19, 2017 | 01:23 PM
troverman's Avatar
troverman
It's all across the Internet that Ford updated or changed the cylinder heads, including Ford's own press releases. Ford isn't lying. Your tech is either looking something up incorrectly or the info simply isn't updated in Ford's system.
Here's a screenshot from Ford's media press release, and the link:
https://media.ford.com/content/fordm...uper-duty.html
Old Dec 19, 2017 | 02:21 PM
Robb81's Avatar
Robb81
I'm inclined to agree that Ford changed the head based on the statement.
But sometimes manufactures revise a part without changing the part number especially if it is backwards compatible.
Old Dec 20, 2017 | 07:39 AM
18F350P's Avatar
18F350P
Ford produced '17 trucks and the next day they produced '18 trucks - all changes were programmed after
GM released their specs - the engines are computer controlled and can be updated .
A tuner that upgrades John Deere Tractors has a module that fits inline after the ford unit so it does not show
on a scan . Uses a four position switch for different hp increases . Ford will not do this due to warranty costs .
Old Dec 20, 2017 | 07:53 AM
troverman's Avatar
troverman
GM released their 2017 L5P engine specs over a year ago, so this is not directly reactionary. Sure, Ford could tune the 2017 engine electronically and make zero changes while increasing horsepower and torque...but in this case they changed the head design. That was done probably in an effort to maintain or improve fuel economy, engine durability, or emissions with the increased power level.
Yes, from one day to the next Ford is producing 2017 trucks and then 2018 trucks. But surely you don't suppose that precludes them from changing the cylinder head design...one day to the next?
I have no idea what you are talking about in regards to John Deere / Ford.
Old Dec 20, 2017 | 07:58 AM
Blwnsmoke's Avatar
Blwnsmoke
yes and the only reason they did that was because the 11 was an all new motor that Ford needed people to buy. The fact the competition came out with more power shortly after the release of the 11, Ford had to do it to keep the 6.7 attractive.
This is not the case for the 17 to 18 MY. Ford's 6.7 has proven itself and now it is about new sales trumping the competition .
Old Dec 20, 2017 | 08:05 AM
troverman's Avatar
troverman
I agree. That power update also came very quickly after the release of the 6.7L Powerstroke. An update at this point for the 2017? The 2017 engine has been in production for over a year...not happening. Besides, it's only a +10/+10 improvement. I highly doubt that will make any difference at all with the power levels being what they are. We're taking about a 2% increase in horsepower and a 1% increase in torque.
Old Dec 20, 2017 | 08:25 AM
Blwnsmoke's Avatar
Blwnsmoke
On top of that, they would have to get emissions certified/approved for the 17 with a reflash which costs $$$.
Easily justified for the all new 2011, Ford won't spend that money on the 17 that is already sold and done with making them.
Old Dec 23, 2017 | 10:56 PM
CaptainFoMoCo's Avatar
CaptainFoMoCo
You are correct new heads on the motor.
Old Dec 24, 2017 | 03:36 AM
brickman's Avatar
brickman
???I don't understand what JD tractors have to do with this.?
Old Dec 24, 2017 | 06:57 AM
jschira's Avatar
jschira
Agreed.
Engine assembly plants and vehicle assembly plants do not necessarily operate on exactly the same schedule.
Engine plant starts producing and shipping a new engine when it has the parts and when it has the production line up and running.
Assembly plants installs whatever engine it receives from the engine plant.
By way of example, just look at the Navistar change over from the 7.3 to the 6.0. Navistar produced a boat load of 7.3s and stockpiled them. Trucks produced in September/October had engines made in May/June.
With modern Just-In-Time production methods, the two plants run pretty much in sync. But some late production 17s could have received the upgraded motor.
Yeahrightgreer
Jul 7, 2018 11:05 AM
AllaboutMPG
Mar 3, 2018 05:31 PM
KingofBolivar
Dec 26, 2017 08:38 PM
jason867
1983 - 2012 Ranger & B-Series
Dec 12, 2008 06:55 AM
