Rear end bounces
Old Sep 27, 2003 | 05:18 PM
krocklein's Avatar
krocklein
Originally posted by Jack01
and as to Kennyrrt putting oil on the brakes will cause many problems and may even result in a brake fire. the braking system is designed on fiction if you reduce the friction then you have reduced the braking capacity. Remember your life rides on your brakes and the life of those on the road
I think he was just kidding
Kevin
Old Sep 27, 2003 | 06:06 PM
kennyrrt's Avatar
kennyrrt
Yes! I was kidding, I assumed a suggestion like that would be rejected out of hand. I apologize.
I only thought of it 'cause when I was in school, even handling the components with bare hands was verboten. The small amount of skin oil might make a difference, no matter how small.
"If he did not have the drums turned down that may be the cause. You might also want to double check to see if the brake shoes are in the correct spot. I believe the primary or shorter shoe is the towards the front." (zieg 96, earlier).
This remains a possibility. The requested picture might help.
Old Sep 27, 2003 | 08:57 PM
Jack01's Avatar
Jack01
i meant no offence towards you and hope that you have taken none....during my years as a mechanic i saw many jobs where the customer had oiled there brakes then brought then to the shop stating that they just did not work right.
Old Sep 27, 2003 | 09:16 PM
stepman's Avatar
stepman
Man, that's funny! I've been turning wrenches for more than 20 and I haven't heard that one yet.
Old Sep 27, 2003 | 09:52 PM
kennyrrt's Avatar
kennyrrt
Unfortunately, he's right. If it squeaks, Joe Poolguy is likely to squirt a little WD 40 in it.
When I was a kid, I had a job doing the teardowns for brake jobs. On more than one occasion, Joe Poolguy had been there before me and actually GREASED the drums. What a mess! Of course, the wheel bearings were fried too. Made us lots of money in parts and labor.
Old Sep 27, 2003 | 10:41 PM
stepman's Avatar
stepman
I would say that that is unbelievable but I have seen other mechanics do some pretty strange things too.
Old Sep 28, 2003 | 06:11 PM
Manwith3fords's Avatar
Manwith3fords
Maybe its a bent rim, loose axle shafts, bad wheel bearings, bad tire, tire out of balance, bad shocks and etc, it could be anything but you have to keep looking until you find the problem.
Old Sep 29, 2003 | 08:49 PM
muzz3256's Avatar
muzz3256
I had the EXACT same problem and took it to a machine shop and had the drums turned and now it's just as smooth as ever.
sduce
1997 - 2003 F150
Feb 6, 2015 12:10 PM
FortiesnBlunts
Dec 13, 2014 08:26 PM
jniolon
13
Oct 29, 2012 07:25 PM
