If you replaced the seal on the hubs then you was in the right spot. Did the hub come off the spindle easy? If the race spins on the spindle then it can get "welded" together and be real hard to remove or it is super easy to take off because the spindle is now undersized from the spinning. Just check the bearing preload and keep it full of gear oil.
That seal was on my 96 SRW, not my 97 dually and yes the hub came off the spindle easy. Thanks for this info, I appreciate it! Good luck with your sled pulling, give em he!!
I bought this with a drain plug and ordered a isspro rear axle temp gauge. I'm curious to see the temps! Sorry Clay, I can't see $319 for your rear cover.
You could of also bought the diff cover from the 08+ super dutys, that one looks nice though.
I didn't know that Adam. This one was fleebay $77 to my door, when I looked at them all over the web I couldn't believe the prices. Come to think of it, there was one on fleebay that they said OEM for $55 or so, I bet that's the one you mean. I liked the cooling fins on this one I got, if they do any good I don't know. I'm looking forward to seeing what temps I'll run.
