1990 7.3 IDI Engine replacement Help!
Old Dec 15, 2017 | 10:41 AM
Dasher400's Avatar
Dasher400
Brother-in-laws 7.3 IDI dropped a valve, head, piston and cylinder are toast. Already ordered another engine. Looking to do the swap over New Years weekend.
I have searched the threads looking for ideas to either pull the front clip or go over the top the old fashioned way. Only decent thread I found is so old the pictures don't load. Anybody know of a good link or thread for a walk through? I have done a ton of engine swaps over the years but nothing diesel or on a 1990.
You guys got any good suggestions?
Old Dec 15, 2017 | 03:10 PM
tjc transport's Avatar
tjc transport
i ain't rite
pull the nose. the idi is rite around 1100 lbs dry.
Old Dec 15, 2017 | 04:14 PM
Chevy_Eater's Avatar
Chevy_Eater
X2 Been there, done that. Clip's easy on these early Fords too.
Old Dec 15, 2017 | 09:31 PM
PlumCrazy7's Avatar
PlumCrazy7
Depends on what equipment you have available. Just a cherry-picker, yeah pull the front clip because the picker will be next to impossible to move. If you have a skid steer or good sized tractor it's pretty easy after you take the fan off and use a come-along or rachet strap to pull the nose way up. Start PB blasting every nut and bolt on the fenders, core support, etc. Here in the rust belt every other bolt/quick nut will strip and make it a bear to remove the front clip.
farmnfly
Mar 8, 2016 04:30 PM
Moe power stroker
Dec 29, 2013 08:33 AM
whiskeyflip
Mar 2, 2009 12:37 AM
Mikestrucks
General Diesel Discussion
Sep 20, 2007 12:00 AM
'961506
May 8, 2005 06:05 PM
