1948 Ford F1 Firewall Holes ??
I am finally to the point of getting some of my wiring and future planning on the engine bay going. I of course did not take great pics of the firewall and now I am wondering where stuff went and/or what holes I can weld up. I have a flathead 6 going back in the truck. Could some of you post some "stock" firewall pics from the engine bay. I know the main few, but curious as to some of the little holes. Thanks guys.
I literally have no pics of my firewall while it was in still together. I am wondering which of these remaining holes are used for. The holes with the blue tape, I have solved. I plan on welding or just putting a bolt in the other ones for a tad bit of a cleaner look. Specifically a few questions.
1. choke
2. vacuum hose from my wipers
3. does the speedo cable come up into the inside of the firewall or the outside
thanks. Just more curious than anything.
Here is a picture of my '50 F2. The holes covered with black tape were open and could serve no purpose that I could see. Most of the small holes around the edges are for the button spring clips that hold the firewall pad in place inside. The big round hole on the driver's side top is where the wiring harness goes through the firewall. There is a metal clamp with two bolts that hod it in place. And the two larger holes above the purple coil are for the heater tubes. I have a Ford heater but there are knockouts for Magic Air and other types.
dmack91
09-29-2013 12:17 AM
going slow
02-01-2009 10:41 AM
AXracer
27
02-08-2006 09:51 PM
