73-79 Battery?
Old Dec 12, 2017 | 11:00 AM
xXANBXx's Avatar
xXANBXx
73-79 Battery?
SO.. What battery is everyone running in there 73-79 and why?
Looking for Cranking amps, cold start, optima red tops or what. Also and why, what are you pushing or feeding
76 F100 302 with nice stereo and mild ignition system and charging etc.: Looking to replace the battery with something better than the old interstate junker that died on me ....
Old Dec 12, 2017 | 12:50 PM
beartracks's Avatar
beartracks
Optima yellow top in all my vehicles.
Old Dec 12, 2017 | 01:57 PM
HIO Silver's Avatar
HIO Silver
73 4x4 - Two Optima AGMs.. yellow tops. Dual batteries. Roof, rock, driving, DRL, and fog lights; ICU cooling fan, winch. 3G powered.
71 F250- Autozone Duralast Gold
70 F100 - Autozone Duralast..3G powered, EFI, and Lincoln Mark VIII fan.
Old Dec 12, 2017 | 02:57 PM
xXANBXx's Avatar
xXANBXx
What made both of you go with yellow top over red top?
Old Dec 12, 2017 | 03:13 PM
HIO Silver's Avatar
HIO Silver
Deep cycle... Excellent ampacity for extended periods of load.
Had a red top before... not enough mojo and it went bad after only a couple of years.
Old Dec 12, 2017 | 03:15 PM
xXANBXx's Avatar
xXANBXx
Awesome sounds good to me
Old Dec 12, 2017 | 03:46 PM
JakeHan's Avatar
JakeHan
Do you think it was the winch that did the red-top in? Curious - looking for some options on a later model diesel that I have for work, has a BIG inverter that gets used quite a bit. Been running a pair of Group 31's with decent success, but.... Was a little scared of a "deep cycle" for winter cold-starts.
On my dents - usually just use Group 31's (they will fit in the box, have to get custom on the hold-down), random brands. Used to like Interstates, don't think they're as good as they once were, had surprisingly good luck with John Deere Strongbox batteries.
Old Dec 12, 2017 | 06:09 PM
Shortbox4x4's Avatar
Shortbox4x4
Optima blue top for me. One I like the extra post for wiring. I’ve got the battery charging cable going to the extra positive post I did for the 3g alternator conversion. Also getting around to hooking up a plow. So another wire/cable for that etc...and with the extra posts on the marine deep cycle battery means less wires hooking up to the solenoid etc....my .02.
Old Dec 13, 2017 | 02:09 AM
boingk's Avatar
boingk
Sketchy $50 cheapie from the local parts store - most likely 'remanufactured' in Taiwan. It claims 270CCA and rated to 50Ah capacity.
Does a decent job of turning over the 11:1 compression 351 Cleveland in my F350!
- boingk
Old Dec 13, 2017 | 08:44 AM
mark-guiver's Avatar
mark-guiver
Duralast Gold in the F250. 1000 CCA @ 32*, 120 AH reserve capacity. Been in the truck for 13 or 14 years and still works, much to my amazement. I've added a little water a couple of times over the years, and in the past it would sit for a couple of months at below freezing temps and still start after cranking to pull gas up to carb. When it dies I'm going dual RV/Marine for more reserve while winching. I have an Optima Red Top in my '71 Bronco and haven't been impressed with it at all. I'll probably replace the Red Top with a Yellow Top or something similar (RV/Marine) when I finish the paint job.
Mark.
Old Dec 13, 2017 | 10:38 AM
jakeharp's Avatar
jakeharp
Interstate
Funny you should ask, my truck just killed a new interstate 750cca, wasn't the batteries fault, truck sat for a few months and has a draw somewhere bleeding the battery and I was dumb enough to keep the cables hooked up .... Tried to bring the battery back to life and couldn't, took back to dealer and they replaced, free under warranty..... Battery does fine for starting truck, hope so for $150.00
Old Dec 13, 2017 | 11:38 AM
xXANBXx's Avatar
xXANBXx
Lots of good info I appreciate it.
I've killed a couple interstate batteries but they are cheap and expendable when it comes to killing. I haven't opted for the marine blue top optima. I'll have to look at that.
Old Dec 14, 2017 | 12:35 PM
D-rat's Avatar
D-rat
I have two batteries....both AGM. One is a Sears battery, the other, an Autozone Platinum.
I definitely prefer the AGMs because you don't get the white corrosion crud on the posts like you do with a maintenance battery.
Old Dec 14, 2017 | 03:56 PM
Ozzie H.'s Avatar
Ozzie H.
Here's a USA made (conventional) battery that's been doing well for me, so far:
https://www.napaonline.com/en/p/NBP7527F
If you can wait, get it on one of their 10% off sales; order on-line; pick-up in the store.
The 27F is a bit stronger than the 24F.
Other places like Sam's can beat the price, but not the warranty.
Old Dec 14, 2017 | 04:28 PM
flowney's Avatar
flowney
I suppose we should mention trickle chargers and battery cable switches for those vehicles that sit and wait a good while for us to crank them up.
